Question about Polaroid FLM-3701 Television
Is there a difference in the Main Unit if the part numbers are: 782-L37K7-560C od the same, just 560B? I am trying to order a new board and mine is 560C, the one I found was 560B. I have heard they should not be any different. Is that true?
  • thedeepsouth Mar 08, 2009
    Thank you so much!
  • 718 Answers
The "C" unit is probably a later version of the board with newer fireware, hardware, less bugs etc.
You can also get a "E" or "C" version of the board.
Try Ebay for a "pulled" unit.
Posted on Mar 07, 2009
My display on my 2003 KitchenAid model KESC307HBS8 range was slowly diming until I could not see the display anymore. I ordered a new control panel 9782419CB and new Main Control Board 9782455 from Sears...
You have not said what problems you are having but want to know if you have wired up the unit correctly. Is that correct?
You are only saying that the configuration is wrong but not that the unit does not work....if the unit happy.
For examp you say the the # 9 key turns on the oven light....are you saying it should be another key?
You may have to restate your problem. Make sure the new board is the one that substitute for your old one. If it is not, they will usually provide you with the package insert to explain the changes or differences.
Oct 19, 2013 | KitchenAid KESC307HBS Electric Kitchen...
Screen is showing a no signal, and is being fed from directv sat
Well try different inputs and also different sources.
The problem may be in the source, might be input specific or might be that the whole board in the TV was damaged, usually as a result of a surge thrugh the cable or antenna.
If the same result is seen with different sources, then you'll need a new main board like this:
Make sure to match the board number in your TV *before* ordering anything!
- bobby
May 31, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Replacement base soeaker for mission 782
I have the same problem too, can anyone know where we can get a replacement of the woofer?
May 11, 2009 | Mission 782 Main / Stereo Speaker
Replace main board on LG 42LC7D-UB
Try this place,
I the best place I know of to get parts at a good price.
There are a couple of boards that have different part numbers. You'll have to match the part# with yours. It maybe out of stock, but click on it. Then click on "find other products with this part number". Then all the main boards show up with that part number. A couple of them should be should be in stock.
Apr 16, 2009 | LG RU-30LZ50C 30 in. HDTV-Ready LCD...
Broken BB 8300 Usb connector . Part number details plse. Got it apart and trying to find replacement part. I am a retired tech so I have a solder ****** and small iron
try ebay and use searchwords "blackberry 8310 USB port". It should pull out 3-4 sites that sell them. The $6 ones are the same as the $19!!! No difference. However be very carefull removing and resoldering the part. If you damage one od the ports on the main board, you have damaged your phone permanently and need to use a external charger from then on....
Mar 10, 2009 | RIM Blackberry Curve 8300
I have a 32" insignia that turns on but a black screen ?
replace the power supply. their are 2 different part # for this model. you will have to take the tv apart to figure that out .
Noes : There are two possible power boards used in this model. Order according to the number on the original.
Jan 23, 2009 | Insignia IS-LCDTV32 32 in. Television
Power loss
Try unplugging and then plugging the TV back in. If you can now turn it back on then you have a bad main board. If this does not make any difference then you have a bad power board. Hope this helps.
Nov 13, 2008 | LG 26LX1D 26 in. LCD HDTV
Phone issues.
1st) you must identify the ranking order of your handsets. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset. Go to the main base cradle. On the bottom, where it says "locator" press the "select" button until you get the desired phone rank needed. H1,H2,H3 etc... Then, press and hold the "call" button, under "intercom". (The charging light should start flashing) Now, go to your handset and press the "OK" button on the top upper right corner. At this point, your phone should be working!
If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support. PS: your handset may show model KX-560B, but your main cradle base will show the actual phone model listed as KX-TG5633
Mar 14, 2008 | Panasonic KX-TG5633B Phone
Televison & Video Logo
108 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
