Question about Whirlpool Washing Machines
Cannot get new motor coupling installed
I bought a motor coupling to replace the one that disintegrated. I cannot figure out how to get the new one in. The part # is 285753a
  • 188 Answers
You will have to remove the motor to get access.
Easiest way is to start by removing the cabinet. With the cabinet off you will have access to the motor mounting clips which will allow you to remove the motor and install the new motor coupling.
Let me know if you need a walk through.
Posted on Mar 07, 2009
How to i fix my swamp cooler
sounds like a alignment problem. take a straight edge between pulleys. also start out with new belt. be sure your using original belt number.
Aug 04, 2015 | Champion Cooler 4000 CFM Down-Draft...
94 oldsmobile 88 crank shaft location
Its the harmonic balancer. The rubber in the balancer has disintegrated and not balancing the motor any longer. You have to install a new one.
Jul 20, 2017 | 1994 Oldsmobile 88
I got your advice on the agitator and I was able to pull it off but there was nothing stuck under it do you think it might be the transmission? It still turns during the wash cycle but its sort of a slow...
It is likely the coupling device that connects the motor to the transmission. These things are a tri-part plastic unit that frequently disintegrates. Refer to:
http://ww.fixya.com/support/r385252-replacing_motor_coupling_w... by jsrock516. This is an instruction for replacing these coupling pieces. If helpful, please give him a pat on the back. Hope this helps get you running!
Jan 30, 2010 | Washing Machines
Coupler between motor and chuck disintegrated, where can I get a replacement coupler for a craftsman rotary tool model# 572.610011? Thx
As of 5-18-2010
The following is available from http://www.searspartsdirect.com
Flex coupling
Part Number: 2615294309
Category: Hardware and Tools
Weight: 0.18
$2.57 In stock
Sep 09, 2009 | Craftsman Single Speed Rotary Tool
Outdoor fan motor is not running fast enough?
Check to make sure that you have the correct voltage going to the motor. It sounds like you lost one of your legs of power which would give you 110v instead of 220v. Or it could be in the pc board.
Oct 15, 2008 | Hitachi RAS-09UH Air Conditioner
Need to replace melted carousel coupling
You need to remove the bottom cover if it's an over the range model.
If it's a counter top type, there should be a cover over the turntable motor.
On many Sharps, the turntable motor cover comes as an unseparated part of the bottom cover and you have to use sidecuts or snips to cut away the little tabs which hold it in place. Then when you are done, you use a screw to hold the cover back in place.
All this is best done with the microwave on its left side with the door opened, and the turntable and support removed. (Power off, of course).
Once the cover is off, you remove the two screws holding the motor, pull the motor out, then pull ou tthe old coupler.
Install the new coupler with one hand, and push the motor in place. Jiggle the couple as you do so it will mesh with the motor shaft.
Once it's in, replace the motor screws, replace the cover and you are done.
Sep 17, 2008 | DCS CMO-24-SS Convection/Microwave Oven
Need the belt routing for my washing machine
unless you washer was bought prior to 1988 there is no belt ..washer is direct drive with coupling between motor and gearcase
Jul 30, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal De
