Cars & Trucks Logo
Chuck Posted on Apr 08, 2013
98 eclipse 2.0 idles high at 2500 rpms an I just replaced the throttle positioning sensor
Just idles high at 2500 rpms runs great just high idle
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Apr 08, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
Helped
6026
Points
19
Sounds like you may have a vacuum leak. any air entering engine not passing through the throttle body will cause engine to race. a whistling sound is sometimes a sign of vacuum leak but not always audible. propane is the recommended method finding leak but I find this unreliable. spraying carb cleaner around suspect areas and listening for a rpm change is more successful. just remember carb cleaner is extremely flammable and caution must be used.
5 Related Answers
Anonymous
  • Posted on Jul 31, 2008
SOURCE: Help - I have a
HI ! YOU HAVE PROBLEM WITH IGNITION CONTROL MODULE. YOU HAVE TO CHANGE IT
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Oct 28, 2008
SOURCE: High Idle Issue
Sounds like the idle speed control motor is stuck, this could have been caused by the cleaning.
Anonymous
  • 56 Answers
  • Posted on Jan 04, 2009
SOURCE: 1997 buick lasabre custom
It sounds like you have a vacuum leak or intake gaskets leaking. Try this. Start the engine and let it reach the idle it want to go to. Get you a can of Brake Clean and spray it around the intake manifold (it on the top center of the engine, you may have to removed a plastic cover) If the engine idle changes up or down then the intake gaskets are leaking hence your vacuum leak. I hope this will help you.
Anonymous
  • 740 Answers
  • Posted on Feb 01, 2009
SOURCE: 2002 saturn sl1 idle too high
Can be but also check and make sure there are NO vacuum leaks or broken vacuum hoses anywhere on intake. I would also suggest if engine light is on is to take this vehicle to an AUTO ZONE they will check by computer for this problem and let you know for FREE. When you get the code I would be more than glad to help you further. Don't guess you may be wasting money and time. Good luck and thanks for using FIX YA
Anonymous
  • 54 Answers
  • Posted on Feb 03, 2009
SOURCE: Check engine light is on and high idle (1500rpm)
Check for a vacuum leak.
2answers
Idles great no throttle response
first check make sure it's not flood out 2 check high speed idle if it has one
2answers
When i start my car in the mornings to warm up it idles for about 5 minutes then the starts to jump up and down from about 1500 rpms to about 2500 rpms one the car warms up more then its from 1000 to 1500...
Try unplugging the mass air flow sensor and see if it levels out.If so I would change the mass air flow sensor.If not try the same technique with the throttle position sensor.
4helpful
2answers
My xj6 runs at high rpms and accelerates on its own
None of those possible problems have anything to do with idle speed. The first thing might be a very weak throttle return spring. The next would be a sticky throttle cable or foot feed pedal that isn't moving freely. Another possibility is a vacuum leak somewhere. Did changing the spark plug in #1 cylinder help the misfire? If not, you may have a partially plugged injector. Fixing the misfire will only increase idle speed some more. Look for an idle speed motor near the throttle body that is supposed to raise idle speed when the engine is cold and lower it back when the engine warms up. Check to see if it is holding the speed too high. If the throttle position sensor tells the computer where the idle speed motor is set, then it could have an effect on idle speed if the sensor is bad. The position sensor is just a fancy potentiometer. Hope some of this helps.
1998 Pontiac Grand AM GT motor revs
it would not be an O2 sensor, period, they would never cause a high idle, have u had this checked for trouble codes? A sticking idle speed control air bypass can cause this problem as well as a throttle position sensor, but run the codes, Kragen does it for free was well as other parts stores.
With clutch pushed-in, RPMs start to go up to around 2000-2500
if it isnt the iac probably the pcv valve positive crankcase vent. it is on a vacuum line somewere under hood. or check the air cleaner, the hose with the small filter underneath the air filter. i take its fuel injected?
I have a 1996 eclipse and the number 2 cylinder is misfiring.
Check the following
  1. Throttle position sensor
  2. Mass air flow sensor
  3. EGR valve
  4. Replace the plugs and wires
Please rate this a fixya
1999 Chrysler Cirrus Lxi 2.5l high rpm
The throttle position sensor may be misaligned. This tells the computer how much throttle is being applied, and when they go bad, or come out of alignment, the idle tends to get up there. If that's not the issue, remove your air cleaner, the housing and everything until you get to the MAP sensor. Give it a good spray with carb cleaner, let it dry and replace the air cleaner with a new one. If the MAP sensor detects minimal air flow, the computer jacks up the idle to compensate.
1helpful
High Idle Issue
2answers
98 chevy 1500 loses power
This sounds like the exhaust is the prob. My guess is the convertor! Frankster016
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
