Question about Whirlpool GHW9400 Front Load Washer
Control Lock is on my front loader.
The control lock in on and I am unable to run my Front Load Washer. Please help me so I can wash clothes
  • 188 Answers
You should be able to unlock the control lock by holding the "end of cycle" signal for 3 seconds or until the "control locked" status light turns off.
If that doesn't work, please post your model number.
Posted on Mar 07, 2009
We have a samsung j845 top loader and a de error came up while it was washing and i cant even drain the clothes
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault.
The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board.
If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Aug 30, 2010 | Samsung WF337AA Front Load Washer
Gorenje washing machine wa 72145 washing clothes but doesnt spin keeps comimg up child lock
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2010 | LG WM2301H Washer
My whirlpool duet 2004 front load washers door is locked, time is flashing and pump is on. Unable to stop or open door. tried to unplug. Control lock is not on. My wife tried to add clothes when the add a...
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader not working - Control Lock Light On
Press the End of Cycle Signal for 3 seconds until the Control Locked light turns off.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
ok, you are in the model selection part of the service mode. for 6240 I believe the model code is 3 select this and press start. normally to release control lock press and hold small I button by start button.
if model selection in incorrect it can still be corrected. only difference in models is cycles matching the labels. you can tell by the time indication for each cycle if it doesnt look right then check book inside top cover
Mar 29, 2009 | GE WBVH6240F Front Load Washer
Affinity front loader ATF7000FGO E23 ERROR
E23 error code means the drain pump relay on the control board failed or wire off pump. You already replaced control board so check the wire at the pump and make sure it's secure.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134879700.pdf
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
Control lock on front load whirlpool washing maching
find button with lock emblem under it ..hold button down for 3-5 secs
Jun 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door can't be opened
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure First disconnect the machine power cable from the wall socket. You should remove machine's top cover and then you will have an access to the door lock unit.
Sep 20, 2007 | Creda W120VW Front Load Washer
Whirlpool GHW9400 Front Load Washer Logo
173 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
