Question about Lexmark X2650 All-In-One InkJet Printer
How do i install ink cartridge in lexmark 2650 printer
  • monique knight Mar 07, 2009
    instrctions on printer are not clear looks like a childs scribbles
  • blue_eyes_ma May 26, 2009
    I have lexmark printer x2650. and some options in lexmark productivitystudio don't works. for example: when I klick on manage cartridges anddiagnose printer, I get info that I need install the service center.and when I try that, I couldn't download.
    Basic problem: how can I install new cartridges?
  • 127 Answers
Go to this site it takes you through the steps and shows you how to do it
http://support.lexmark.com/perl/support/support.cgi
hope it helps
technohelp
Posted on Mar 07, 2009
  • 1,602 Answers
OPEN THE COVER OF THE PRINTER AND THERE WILL BE SOME TYPE OF INSTRUCTION ON HOW TO INSTALL NEW INK CARTAGES, SOME MFG PUT THE INSTRUCTION IN THERE OWN BRAND OF INK.
I refilled my Lexmark cartridge but it continues to say I need to install a new cartridge. The printer model is x2670.
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Feb 17, 2011 | Lexmark X2670 All-In-One Printer
How do I change the ink cartridge in a Lexmark x2330
  • Turn the Lexmark printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
  • 2
    Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps.
  • 3
    Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
  • 4
    Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
  • 5
    Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you've completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
  • 6
    Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
  • Jan 17, 2011 | Lexmark X2330 Printer
    How to replace the ink cartridge
    1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
    2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
    3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
    4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
    5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
    do rate the solution if it helps
    Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
    I have a Lexmark 2650. I have installed new
    Your color cartridge backed out re install it and you should be fine
    May 28, 2010 | Lexmark X2600 InkJet Printer
    Lost my manual, need to change the ink cartridge, help
    3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
    4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
    5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
    Apr 24, 2010 | Lexmark C533DN InkJet Printer
    I installed a new cartridge. It was exactly the
    Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
    Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
    If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
    They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
    If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
    Don
    Dec 12, 2009 | Office Equipment & Supplies
    Trouble refilling lexmark 2650 ink cartridges
    hey dude have you find any solution for your problem?? i've got the same problem here :( can't do anything
    Aug 16, 2009 | Lexmark X2500 All-In-One Printer
    Does not work lexmark x 2650. is there any way to reset old refilled cartridges no.14 and no.15
    “Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
    May 21, 2009 | Lexmark X2500 All-In-One Printer
    I have a lexmark 2650 all in one. I bought some
    That is why Lexmark does not endorse or authorize remanufactured cartridges on their products.
    Your only recourse is to see if the vendotr can get you working cartridges, or purchase Lexmark cartridges.
    Apr 15, 2009 | Lexmark X5150 All-In-One InkJet Printer
    Using a refilled ink cartridge on a Lexmark x4850
    Yes, most Lexmark cartridges as well as many other manufactures use something called 'Smart' Chips in the bottom of the ink cartridge. Usually unplugging your (about 10 seconds) printer resets the memory in the printer. Hope this helps!
    Mar 20, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
    Lexmark X2650 All-In-One InkJet Printer Logo
    440 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
