Question about Gateway Profile 4 XLb PC Desktop
I installed a new hard drive in a Gateway 4XL.
I have installed a new hard drive in my Gateway Profile 4XL. When running the restoration CD to install Windows XP and I get Windows Setup. When choosing re-install Windows or repair Windows, the next screen states that hard disk drives cannot be found.
Sounds like the HD will need a low level format from a boot disk or a boot CD.
If it hasn't been done then the BIOS won't see it and Windows CD won't either.
If you have another system available, you can set it as a Slave or Cable Select, plug it in and format it from that system if the OS can see it at all.
Some HD's used to come with that disk. Most don't need it now.
Of course...it may be a dead drive too..........
Tony
Posted on Mar 07, 2009
  • 21 Answers
See your hard disk Jumper setting it could be wrong change jumper of your hard disk then install the windows.
Hooking up a Internal Hard drive
You probably need to give more details. If it's a replacement drive, did you reinstall Windows from a CD? Did you copy from the original hd? It's simple enough to remove the two cables from the original drive, physically remove and replace the drive, and hook up the new drive. But then you'd need to boot to a Windows CD in the CD/DVD player to format and install Windows, if that's what you're attempting to do.
There's possibly a recovery partition on the old drive )or a recovery CD). If so, you'd connect the new drive to a second power cable, and data cable (which might not be included in the tower) :
(from http://support.gateway.com/s/Manuals/Desktops/8510406.pdf)
To restore system software from the Recovery discs:
1 Insert the Recovery disc #1 into the CD or DVD drive.
2 Restart the computer, then press and hold
R when prompted to display the restore process options. The
Options menu appears.
3 Select a restore process option:
- Press R to boot from the hard drive recovery partition
or CD. If no recovery partition is found, go to Step 4.
- Press F to format the hard drive and perform a full system
recovery, then go to Step 5.
4 Click a system restore option. For more information, see
"Restoration options" on page 5.
- Non-Destructive System Restore (Recommended)
- Full System Restore (Destructive)
- Full System Restore (with Backup) (Advanced Option)
5 Follow the on-screen instructions to complete the system
software restoration process.
Oct 29, 2013 | eMachines ET183105 PC Desktop
System recovery on a gateway 6214 laptop
Try This:
    • 1 Back-up any important files to an external hard drive, if at all possible, before proceeding.
    • 2 Place the Windows Install CD into the computer's optical drive. Restart the computer with the disc inside. As the computer starts up, it will prompt you to press any key to boot into the Windows Install CD, press any key to do so
    • 3
      Press "Enter" to bypass the "Welcome to Setup" screen. Press "F8" to accept the Windows License Agreement. Windows Setup will ask if you'd like to install any available updates to the operating system. If you currently have a (wired) Internet connection, download the updates. If you do not, you can install the updates after the restore completes.
    • 4 Select the "Custom" installation route. Select the internal hard drive as the installation destination. Press "D" to delete any and all data on the hard drive. Confirm this action by pressing "L". Press "C" to create a new partition to install Windows. You will need to use the "NTFS" file system, as this is the Windows default.
    • 5 Continue the installation by following any on-screen instructions. You will be asked for the Product Key, your region/time zone and to create a name for the computer. The whole re-installation, reformat and restore process will take a little over an hour. Once complete, the computer will reboot to apply the finishing touches. Remove the Windows Install CD at this point to avoid booting back into the disc. The Gateway laptop will launch into a freshly restored Windows installation.
Jul 18, 2012 | Gateway MX6214 Notebook
Installed new hard drive (old one crashed) no sound now
You need another sound system. If it's xp it is probably ac 97. However; go to windows update, make sure you have all of the updates. Then go to the control panel, device manager and look for a yellow question mark or a yellow exclamation mark, if there, right click and click update driver or click uninstall from the system, restart the computer and windows will look for the drivers, just follow on screen directions.
Jul 08, 2010 | Gateway GT5228 PC Desktop
I have an older Gateway laptop that I rarely took out of house
you'll have to buy a new but tough to find 2.5'' serial-ATA hard drive, this should solve your problems but you'll have to reinstall any operating system and also all of the data on the current hard drive will be lost.
Apr 25, 2010 | Gateway (M520HD80G) Hard Drive
My motherboard for my laptap MX6025 was damage, now I am replacing them for a new one and would order via online. How do I install this to my windows xp, what requirements do i need such as drivers,...
If your hard drive is still working fine, you shouldn't need to reinstall Windows again. Most of the time your PC will perform as it did before your motherboard died by simply reinstalling the original hard drive.
If not then do this.
Reinstall windows with your restore CD, and with most gateway laptops you should have a drivers and applications CD that restores your motherboard drivers and applications to their original locations.
If you lost your drivers CD, you can download them all here.
http://support.gateway.com/support/drivers/search.asp?st=pn&param=5376
When asked, you should allow XP updates so that Service Pack 3 can install. This will add a few windows based drivers to your laptop that may be necessary for better video, audio and wireless performance.
Your restore CD may not ask for your CD Key, this is typical for a Vendors original restoration, but if for some reason it does, the number on the back of your laptop will work. Mine validated just fine.
Apr 02, 2010 | Gateway MX6025 Notebook
Mx6128 gatway hard drive
The smallest hard drive that can be purchased is approx. 100Gb. You need a Windows installation CD, and provided you have the product installation code (it should be on a Windows label on the bottom of the laptop) installation is fairly straight forward. You may be able to get a Windows CD from a computer shop, they may install Windows for you at a cost. You need to download the device drivers for the laptop from the Gateway WEB site.
Jun 05, 2009 | Gateway MX6128 Notebook
I have a gateway Profile 5. when i cut it on
My understanding is that when you power on your PC, the POST is succesful, but then the system hangs.? If i am correct. There are several reasons this may happen.
1) Boot record corrupt
S) Reformat the harddrive and re-install operating system / replace hard drive
2) General Hard drive failure but boot record instact
S) Replace Hard drive
3) Operating system inoperative
S) Re-install operating system
Most pre-built systems come with recovery disks, you may try this as a solution if available.
When replacing a defective hard drive, or partialy inoperable hard drive, a good policy is to change the drive to slave, and install the new drive as master, this way any data you may be able to recover, can be done after the new hard drive is installed, and an operating system is installed on the new drive.
(POST = Power On Self Test)
May 12, 2009 | Gateway Profile 5 PC Desktop
Cannot get Toshiba P@% S507 to see new hard drive.
you can't use a restore disk made for a specific hard drive with a much larger hard drive. This information is checked by the restore cd. You would need to contact toshiba and get a regular windows install cd.
Apr 01, 2009 | Toshiba Satellite P25-S507 Notebook
Gateway M305CRV
i have a gateway m305crv my wireless wont work does not recognize the card so my wireless wont work tried so drivers but still does anyone have a solution...thank you
Feb 14, 2008 | Gateway M305CRV Notebook
Hard drive not working properly
What is the original OS? If it's XP you can't install 98 over the top of it without formatting it to FAT32 first.
Nov 07, 2007 | Gateway Essential 500 PC Desktop
Gateway Profile 4 XLb PC Desktop Logo
131 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
