Question about Craftsman Heavy Machinery
The pull string locks up
The pull string to start the engine keeps locking up. Ill pull it a little bit out then it will lock. Ill let it loose and pull again and another 2 in will come out then it will lock again etc. i can do this until the whole string is out then let it wind back up but it will do the same thing again. How do i fix this problem?
    Top Expert:
  • Craftsman Master
  • 6,233 Answers
Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem. Best Manuals
Posted on Nov 28, 2017
SOURCE: Singer 7442 Bobbin Will not wind
to wind a bobbin you get thread and put it where it usually would be put it behind those 2 metal piece (see pic in manual) and there put it around the thread guide and then u put the tip of the thread through the hole of the top of the bobbin from the inside to the outside  and u are really to start, u should already have the bobbin and the spinning metal piece, then u move the metal piece to the right into the notch and press the presser foot and hold it until it stops you and you're done :-)
Posted on Mar 27, 2008
rowdy45176
  • 2176 Answers
SOURCE: Bits will not lock into chuck
First I would go to Makitatools.com and download a schematic for this tool. But it is pretty simple to remove the rubber dust shield and plastic collar to look for debris and proper movement in the chuck assembly. Make sure also that you are using the right SDS bits in tool. You should be able to push the bit into the collar and twist until it goes into and locks. Let me know and I will help further
Posted on Jan 11, 2009
  • 3 Answers
SOURCE: Pull string locked up
check oil , if you didn't have sufficiant oil you may have blown the motor up . try turning mower up and turnning blade by hand to see if motor is froze. if so you can kiss this mower goodby ,or at least the motor. sorry .by the way maybe you would want to check the oil in your car before you blow it up too
Posted on Jun 08, 2009
  • 81 Answers
SOURCE: Sears Model 358.791070 Trimmer Overheats and
Possible the fuel was too lean or something managed to enter the piston area through the air filter and locked it up. Possible scratching on the piston.. Time for a new trimmer.
Posted on Jun 17, 2009
  • 8 Answers
SOURCE: I found a loose spring to my door lock 99' Ford Explorer.
76df6f5.jpgthis This is what you have to do.Go to the hardware store and get a spring just like in the pic maybe smaller. Put the bottom side just like in the pic and the top side of the spring on the door cilynder. And you are done.
Posted on Jun 23, 2009
I cant pull the string to start the mower
pull plug out tie up bail handle see if you can turn engine over by hand if you can pull hard on rope it has jamed if not .move check for locked up mover add oil to cylinder for it to turn over till its free my have to take recoil off to do this if the reciol starter pawls or lock in
Aug 30, 2014 | Garden
How can I replace the ignition lock and the drivers door lock on a 1993 300zx?
You will probably need to drill out the center of the ignition lock cylinder to remove it without the key. Start with a small bit and make sure you drill straight into it and then use a little bit bigger drill bit. Keep doing that until you can turn the key lock cylinder and you'll be able to remove it.
May 06, 2014 | Cars & Trucks
Pressure Washer Pulls once then locked up.
sounds like the valve might be stuck open
Aug 06, 2012 | Garden
The spinning device (the filament cassette I think) through which the cutting strings are attached has detached from the trimmer's stick. How can it be put back again or reattached?
There should be a knob that goes on AFTER the string spool that holds it on. IF the issue is it keeps turning when you try to put it back on, then on a machine with no clutch, the engine will need to be locked up. To do this, remove the spark plug and wire, pull on the start cord until you see (with a light) the piston go DOWN in the cylinder...then insert a length of soft, clean rope into the cylinder and this will lock it up when it tries to turn again.Parts on end of the machine are:
1. Bump Knob 2. String Spool 3. Spool Spring and finally 4. String Head Housing
Aug 14, 2011 | Homelite Mighty Lite Lawn Trimmer
When pulling the string to start the weed eater it feels as it's locked and won't pull out more than an inch I have set it to full choke half choke also primed it nothing works how do I get it...
If this is a 2 cycle engine , which most weed eaters are, then it sounds like probably the piston is locked up inside the cylinder. Try taking the spark plug out. if it still will not pull out then take the recoil cover off. There should only be 4 screws holding it on. Once you get that off see if the string pulls out of recoil if it does then check to see if you can turn the crank on the engine.If the recoil string does not pull over then that needs to be repaired or replaced. If the crank on the engine will not turn over by hand then your engine is siezed. If you take the covers off to expose the exhaust there are 2 bolts that hold it on take those out and look inside. If you see vertical scoring on piston then your machine isnot worth fixing
May 15, 2011 | Garden
Hi! Error dE1. Dear, Boris From Russia
Code de1 came up, on my big wash. DE1 means door error code 1, which I think is door not locking. (Judgeing by previous posts). The door didn't electronically lock (clunck), so me and the wife took the top off to have a look inside. Could see the door locking mechanism, (brown plastic) and the orange override manual opener. Turned off power at plug (don't want to electrocute myself) Pulled the orange cord about, that didn't do anything, still error code de1. My wife with slender arms got her arms down there and a connector came off. She could get it back on, so she pulled the drum outof the way, and I got my arm in and put the connector back into its point. (It can only go in one way. So if you have problems, you may be putting it back round the wrong way.) Power back on at plug and it started straight away, door locked and everything seems to be fine, it is now washing away merrily. So it turned out to be a loose connection. Lastly the orange manual override pull, took us ages to put it back, idea, tie a long bit of string to the pull at the bottom, so you can easily retrieve it back down the hole.
Apr 02, 2011 | Washing Machines
When i lock the tuning locks the guitar is out of tune within 3-5 minutes of locking, then when i try to re tune it the strings snap. whats the problem?
I am not familiar with your model of guitar, but I assume it has a tremelo system. Usually when a string breaks at the nut like that, it's because the metal piece that locks the string is not smooth, has a burr on it. It could also be that the lock is holding just well enough that when you bend a string it is slipping some but doesn't go back all the way. Try just totally unlocking it and playing a bit to see what happens. The friction may be wearing on the string where it contacts the lock. I am assuming it is breaking near the nut/lock area, is that right? Or is it breaking at the bridge end?
Jan 14, 2011 | Schecter Synyster Standard Electric Guitar
How to undo and change the cutting line
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** (bottom) of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Apr 13, 2010 | Homelite Mighty Lite Lawn Trimmer
I can't start the car!
Try turning the steering wheel a bit when using the key. The steering wheel lock puts pressure on the lock cylinder to keep the wheel locked. If this pressure is high, it can keep you from using the key.
Mar 05, 2010 | 2004 Lincoln LS
Lawn mower died. Pull rope locked up
remove the spark plug and try to pull the rope. Sometimes the coil can get loose and wedge against the flywheel. if that's not the problem then pour a little oile in the spark plug hole, let it set a bit, if it still won't turn over then you have an internal engine problems. Not very common but it can happen
May 09, 2009 | Garden
Heavy Machinery Logo
283 people viewed this question
Top Craftsman Heavy Machinery Experts
ray gallant
 steve
steve
Tom Chichester
Are you a Craftsman Heavy Machinery Expert? Answer questions, earn points and help others
