Question about Toro Garden
How to remove plastic front wheel drive cover on Toro Recycler
The cover looks like it should just snap loose, maybe with a screwdriver, but I don't want to break anything. I was mowing when the self-propulsion feature suddenly quit woking. The drive belt does not appear to be broken, but is loose and the drive mechanism will not engage. Suggestions will be appreciated.
Thanks,
Jim
  • 2 more comments
  • tipecanoe_20 Mar 07, 2009
    It is a Toro 22" Recylcer
  • cade49 Mar 07, 2009
    I have a 2008 Toro 22 in recycler and the self propel quit working and the rear wheels will not turn backwards. I tried tightening the cable as described in the manual, but that did not help. I am curious about how to remove the cover for the drive belt.
    Alan
  • tipecanoe_20 Mar 08, 2009
    Thanks for your comments. The first thing I checked was to see if the drive shaft was clean, and it was much cleaner than I expected.Is the screw on the top of the deck or below the deck? I have not found it yet. Update: I think I just found it below the deck near the front.- Thanks again for your help.
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello mr t, is this mower a toro or a sears.
On my Toro recycler, I also had the front drive stop working -- and fixed it after reading the solutions here.
First, the plastic cover on the top deck that goes over the front drive mechanism must be loosened enough to pull it up. Before you can do that, on the underside there is one screw to take out.
Once that's done, all you have to do is pry the plastic cover up enough to see the belt and pulley that make up the front drive assembly. On mine, the belt had simply come off the pulley. Putting the belt back on, then tightening things back up is all it took to put the Toro back in sel-propelled happiness. Good luck!
Posted on Sep 05, 2010
  • Mike McLoone Sep 17, 2013
    I had same isue but it was a small piece of wood that knocked it out of pulley following hints I was able to fix it saved $ very unusual for me as I am not Mr Fixit thanks to this blog
I just found them. One at the left corner of the cover (standing facing the front of the mower) the other to the left of the opening where the cable enters the cover. You access them both from under the mower.
Posted on Oct 20, 2012
  • Earllene Bond Oct 20, 2012
There were TWO bolts/screws (10 mm; I used a 3" socket to remove); located underneath; one is near the front wheel, the other covered up with dried grass near the blade housing.
Posted on Sep 26, 2011
Toro 22" recycler Mod
Got the same problem with mine, replaced the drive belt, removed the wheels and checked for rocks and pebbles, greased, checked also bottom of gearbox. grease was present no broken teeth, top pulley has excive side to side play. Have not disaasembled yet. Hope someone would have had a solution here.
Apr 11, 2011 | Toro Lawn Mower With Toro Power Tools
How do you replace a drive cable on a toro recycler 6.5 hp.
Its a bit of a pain - but with ordinary tools, it can be done. Get the replacement cable first. You can see how the bottom spring wraps around the cable with a universal joint sort of arrangement. Remove the belt protector (three screws from the top deck; if you have a battery compartment, that will temporarily need to go. Release the old cable from the top and middle attachment points, then unhook the spring from the traction lever. You might need to destroy the old cable lock to the mower deck to remove the old cable. Remove the plastic cup next to the cable where it exits the mower deck. Replace parts in this order: New spring/cable to the traction lever, snap in plastic interface to mower deck, small plastic cup top cable attachment, then middle attachment. You might need to move the middle attachment after you give it a test run. Replace belt cover and battery compartment if necessary. A lot of steps but, except for a difficult fit to get the spring hooked up, nothing is really difficult. I paid about $30 for the replacement cable from a local dealer; Overpriced, but I wanted to get the job done today.
Oct 15, 2010 | Toro Lawn Mower With Toro Power Tools
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
Front drive wheels won't engage
Is it possible that the belt has either broken or come off the pulleys? Next step would be to remove the cover and see if there is something preventing engagement or if you see any broken parts. May even be as simple as lubricating the cable/levers.
Apr 10, 2010 | Toro Lawn Mower With Toro Power Tools
I have a toro recycler 6.5 horse front drive. the drive wont engage properly. it makes arattling/grinding sound and i wind up having to push it. i already replced the drive belt with no improvement. i...
As a quick guess (without looking anything up), you might want to look and see if this is:
a. a "direct-drive" (where the wheels are affixed to the drive shafts) or
b. a "gear-drive" (where the wheels are attached to their own spindles, and have "teeth" molded into the inner circumfernce of the wheels, and there are correspondent gears on the ends of the drive-shafts, whish engage the teeth on the wheels), in which case, the problem is quite possibly crud/mud and/or wear on the teeth...
The alternative is, of course... the "transmission" (which often has plastic gears in it...) - but, it's re-buildable... if you can find the parts... and if you can't... then it's replaceable, with a bit of work.
One bit of advice, though... when you're cracking the trannie, make sure that you make careful note of what gear goes where... on my first one, I didn't, and it took me several hours to figure out what went where, after I collected all the parts...
Oct 28, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Garden Logo
6,799 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
