Question about Thermador C302U Electric Double Oven
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same problem. The broil setting and Convection oven setting will work, but the bottom element will not get hot. Any suggestions appreciated.
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Posted on Jan 21, 2011
Thermador smw 272 not heating via bake or convection. Light and fan work as well as broil and clean (microwave fine too). If I switch from broil and then to bake after heated, it will hit right temp and...
see if there is a bad solder connection on the bottom (underside) of the board just below one or more of the small black relay boxes. re-solder if you can or replace the whole board.
Jan 04, 2015 | Thermador Ovens
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
Bake element does not heat up but broiler does. Do
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 06, 2010 | Thermador SMW272 Electric Double Oven
Thermador smw272y won't heat at all
The switches on the first circcuit card mounted horizontally in the space above the microwave enclosure and behind the control pannel have burned to the point that they no longer engage properly to close the power to the oven heating elements. I do not know anyone who has removed the plastic covers and cleaned them to the point of working again properly and do not recommend trying that approach. The only sure solution is to replace the circuit card that has the three switches.
Sep 01, 2009 | Thermador SMW272 Electric Double Oven
Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Dec 12, 2008 | Thermador SMW272 Electric Double Oven
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
May 28, 2008 | Thermador SC272T Electric Double Oven
Thermador C302U Electric Double Oven Logo
785 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
