Question about Motorola T5710 (22 Channels) 2-Way Radio
Will not unlock
T5710 will not unlock. Rings when first turned on. Cannot transmit or recieve.
Motorola T5710: how to turn off beep after I press mic button?
You can find the manual here: Motorola .
You can also go to Get Support for more info.
Motorola Mobility Support
Mar 19, 2015 | Motorola T5710 (22 Channels) 2-Way Radio
Cannot set interference eliminator code on my second t5710
First check to see that your keypad is unlocked. You can lock/unlock the keypad by holding in the PTT button for three seconds. You will see a little lock icon when it is locked.
To set the code for a channel:
1. Press Menu until the CODE number begins to flash.
2. Press the + or - to select the desired code.
3. Press the PTT to save the code.
Note: You can set a different code ofr each channel using this procedure.
Zero (0) equals OFF.
If you continue to have problems, set both radios back to a very basic setting with all special featured turned off and see if you can communicate. Then add the desired features back in one at a time until you have what you'd like on both radios.
Best regards.
Oct 06, 2012 | Motorola T5710 (22 Channels) 2-Way Radio
Unit has power but no sound and does not transmit
Here's a link to the user guide:
Check the settings for the frequency, code and Qt filter. They must be set identically on all radios in the group. If you are still having trouble after doing this, try shutting off the code and the Qt filter. (Usually setting to off or zero)
Best regards.
Dec 25, 2009 | Motorola T5710 (22 Channels) 2-Way Radio
Submerged one t5710 unit crossing a river; no longer transmits.
Probably not.
The electronics in the transmit / recieve circuitry (RF = radio frequency) work very differntly from those in the display and control circuits, which prob ablyexplains why the display works, but not the rest.
The major problem with water in RF circuits is that even after it dries out, it leaves a residue, or worse still some corrosion, which adversly affects the tuning of the RF circuits.
It may be worth trying to dry it out a bit more - put it somewhere warm but not humid like near but not too close to a central heating boiler, for a few days. However, I suspect it is now beyond repair.
Oct 07, 2009 | Motorola T5710 (22 Channels) 2-Way Radio
Receiving "Unlock" message and "Not Used" on my reciever
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock" and you will get sound. The only purpose for the HDMI jacks on this reciever is to give you a bonus HDMI jack so you only have to use one on your TV. I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's.
Dec 30, 2008 | Sony STR-DG520 Receiver
T5710 die
Check your Qt filter and be certain it is set to zero on both radios. If you are certain each of the setting is the same on both units, your dropped unit may be no longer functioning. Sorry.
Oct 20, 2008 | Motorola Talkabout T5720 (7 Channels)...
Won't receive or transmit
Here is a link to the user manual:
May 31, 2008 | Motorola T5710 (22 Channels) 2-Way Radio
Moto T5710 Disassembly - Transmits Carrier Only. No Modulation.
Hello bwilliam. Batteries can give you a false reading. Check your batteries under load. Good luck.
May 22, 2008 | Motorola T5710 (22 Channels) 2-Way Radio
Utilizing two microphones
No, when you buy multiple wireless mics you have to select different channels per unit if you want to use them on the same stage.
hope this helps
thanks for your rating
Jan 09, 2008 | AKG (WMS40DIV444US54) Microphone
Radio Communications Logo
59 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
