My Whirlpool front load washer is in control lock I need to know how to undo?
  • 501cjd Mar 07, 2009
    I have a Whirlpool front load washer Model# GHW9400PTO Serial # CSS0514417 It is stuck in control lock and I do not have my manual so I am unable to wash clothes.
    Genius:
  • 3,422 Answers
HI,
Please hold the "end of cycle" alarm button for 3+ seconds to unlock it.This will fix the issue.
Posted on Mar 07, 2009
  • Priya darshan Mar 07, 2009
    If that doesn't unlock it then just unplug all the cords of the washer for 4 hours,even the power cord and allow it to reset.After 4 hours plug the cords back in and it should be unlocked.In case it doesn't then hold the "end of cycle" alarm button for 3+ seconds.
  • 154 Answers
What you want to undo?
  • 1 more comment
  • crysiszone Mar 07, 2009
    please give the model number and explain little more of your problem?
    is there any error code on the display?
    unplug the machine for 1 hr. and try again to work on it.
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to undo control lock button
Hi- You should just be able to hold down the lock button for about 5 seconds and it will go off. Good luck.
Sep 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: whirlpool washer says control locked, how can we f...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked Light on washer? How do I undo?
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel.
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
NOTE: If you cannot locate your owner's manual, you can download or print a FREE copy at managemylife.com. Just type in your model number under the "Manuals" link and you will find your manual listed in a .pdf (Adobe) format.
Jan 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I undo " control locked" ? Thanks
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Dec 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to undo control lock on duet front loader?
Press and hold the end cycle signal button for three secounds.
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet front load washer control locked--How do I undo??
Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom
of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Nov 19, 2007 | Whirlpool GHW9200L Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
