Question about Logitech QuickCam for Notebooks Pro Personal Web Camera
When I try to record a video useing another mic source after 35 seconds a pop starts like a pulse
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Posted on Mar 31, 2009
How do I record from an external source (IPOD)
If recording from an iPod to a computer you need recording software like Audacity and a orch cable. Plug your patch into the input or mic plug on your pc, plug the other end into the iPod. Start the recording software select the input, start playing the iPod and hit record.
Mar 06, 2011 | Audio Players & Recorders
I have a behringer xenyx 1204usb mixer with a mxl 990 mic and i have problems with static. thats all i have hooked to the mixer so i dont think its a conflict. i have tried recording in audition, pro...
Yep ! First thing is to eliminate any processing resource "hogs" that **** respources and can cause buffer overruns. Eliminate Antivirus, antispyware, and network communication and wireless network programs running in the background while recording.
Next make sure that ALL equipment is powered from the same receptacle or power source. In your case that should be the mixer and the PC.
Next remember that the condenser mic picks up everything... I have 5 of those mics and seemingly noise free environments turn out to have little things that generate fast rising pulses that you don't notice till they are recorded.
Lastly, the air here is very dry and plain old static electricity is rampart... Lady shuffling her feet was sending pulses through the mic cable at our church. They are NOT audible until they get into the sound system as clicks.
I have found that trying to record directely to a USB stick often has ooverruns and clicks... also burning a CD from stick to the CD results in noise due to buffer underuns. Burn from Hard drive to CD and make sure all the other hog programs are shut off.
Jan 04, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have a DELL Studio 1737 running Windows 7, with integrated web cam. i am trying to make videos with web cam and video is perfect but no sound on playback. Dell webcam central is what i am using to make...
Sounds like a software issue, possibly with webam central. There's a free player that has good codecs, and it may help you. Here it is:
http://www.finalmediaplayer.com/
This will be an easy fix if it works.
Jul 31, 2010 | Computers & Internet
Can't record clear sounding video on either my mini or my laptop.
A better idea is to use a digital camera with sound, switch to video record and make your video with that then copy that AVI file to your PC. But if you really want to use the PC make sure that your Audio source is selected in the recording devices section of audio properties as Microphone, then turn off mic boost. Slowly bring up your mic volume with the headphones attached until you can hear yourself clearly. Cranking it up too far will result in over-modulation and distortion. And finally, remember that most microphones included with laptops and Desktop PC's are cheap hetrodyne models with limited filtering and cheap plastic domes for audio pickup. The more you pay the better they get.
Something worth mentioning here.
I have actually had success recording with Cheap headphones on the Mic port before. Not headphone mic combos, but the actual Headphones. This gives you an idea of the sensitivity of these pickups.
Mar 14, 2010 | Computers & Internet
Dell dimension4600. microphone does not work. I have a portable microphone connect to the pink mic connection.
it might be a bad mic or it may be your mic settings
its worth looking into, try connecting a audio source to it when you are configuring it and have the volume control for the microphone (on the playback section) so that you can hear it when it starts working
Jun 13, 2009 | Dell Dimension 4600 PC Desktop
Internal mic does not work
Be sure to find up-to-date drivers for your mic. What kind is it? That is most likely your problem. Either that, or you installed something that is conflicting with it.
Apr 06, 2009 | Acer Aspire 5315 Notebook
We cant record a video clip with sound - only picture
You need to go into the recorder options ant tell it the sound source to us is the USB Mic. on the webcam, or what ever the source of the Mic. is. There are several sources in Skype that allow changes to be made. Use the drop down menu for the selection and select the one you are using for the mic. Good Luck, RAC
Mar 28, 2009 | Logitech QuickCam Connect Webcam
At Step 4 of the installation, each time I hit "Start Recording," I get a pop-up message that says "Please enter a valid record time." But, it will not let me enter a time into the box.
it is becuase the dazzle capture device is not selected as your video source. Please try to go back to step number 1 select video source . Make sure that pinnacle file capture is not selected but the dazzle is selected then try it again.
Feb 22, 2009 | Pinnacle Dazzle DVD Recorder
No recording?
The static after several seconds seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
You can double check that this is the problem by trying it on a Windows computer.
Jul 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Logitech QuickCam for Notebooks Pro Personal Web Camera Logo
47 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
