Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan chain saw. After starting, chain drive won't move
My chain saw will crank just fine.  When I give it some gas, the chain will not move.  After I take the cover off and take the arm off, I try to move the drive that actually moves the chain.  It will not move.  It is frozen.  Are there any suggestions out there?  Much appreciated.
  • fla_hd_rdr_1 May 25, 2009
    I have the same problem. It starts fine and will run at idle but when I give it gas she bogs down and the chain will not move. It seems if the brake is not disengaging or the clutch is seized up.
  • Anonymous Mar 17, 2014
    saw used 2x's. Has been fine. Went to start today and on/off switch and choke do not move.
    Have tried with brake on, or off.
    Can't fugure out whats up. no mention of this issue in manuel or help line
  • 152 Answers
If equipped, the chain brake may be engaged. Its the lever just ahead of the fore handle. (pull back on it)
If the clutch assy. were frozen, then the chain would move all the time.
Good luck
Posted on Mar 11, 2009
Have a stihl chainsaw that's probably 10 yrs old. Will start ok but the chain won't move when given gas. It revs but won't move.
I guess the first thing to look at is chain free to move ?, do this with saw off ! and not running , if its not free to move give a good look at the chain brake , if chain moves free with a gentle push , then your clutch is in need of replacement good thing as stihl makes parts for there old saws still too , now if your saw was 20 yrs old your clutch is rebuildable
Apr 26, 2015 | Stihl Garden
1995 Olds Silhouette rattled badly, died while running
I think you had better have a local shop inspect this for a failed engine connecting rod.
Aug 23, 2012 | Oldsmobile Silhouette Cars & Trucks
How to change the chain on chainsaw
Most saws are pretty much the same's a decent link. Some saws will give trouble if the brake is on when you remove the side cover so make sure the chain moves freely before removing the side cover.
Here's one on tensioning the chain...
Dec 07, 2010 | Homelite ZR10926 16" Chain Saw
Chain saw starts and runs chain is moving at high speed but when placed against log it slows to a stop and does not cut, what should I do
Remove the clutch cover, bar, and chain. Wash out the interior of the clutch with spray carburetor cleaner to get rid of oil build-up. Reinstall the bar, chain, and cover after cleaning the bar drive-end small oil passages that run out to the chain groove. Adjust the chain up to the bar, but not so tight that you can't move the chain by hand. Hope this helps!
Jul 29, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chain saw chain stopped moving
Was it running and shut down and was froze or when you went to restart it was frozen? Two things I have seen cause this other than a seized engine. One - chain bound up. Remove side cover and inspect chain mechanism. Two- the pull cord is bound up. Remove the pull cord cover and inspect.
Jun 15, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chain brake is jammed, chain will not move when cranked
Take the side cover off of the clutch area and watch while you try to move the brake. Something may be broken or out of place. If the brake band which is fitted around the clutch drum is damaged, it may be causing non-release.
May 13, 2010 | Homelite ZR10926 16 Chain Saw
Mccullough chain saw pm610 chain slips -- maybe clutch issue
have you greased your clutch bearing ever.some times they get dirty and tighten up after running a while.pull your clutch off and clean and grease bearing with a little alex grease,and I mean just a few drops.not meant to have a lot of it,too much will burn the crank shaft and you will have more problems then you started with
Jan 01, 2009 | Garden
Tightening chain
with the electric makita you should make sure the bar is sitting on that oval slide piece on the saw. they should fit together so that the bar will sit flush against the clutch plate and saw. attach the cover with the nut and tighten just enough to hold the cover on. then turn the screw on the nose of the saw, next to the bar, and then tighten the nut the rest of the way. if there's slipping or the chain wont tighten you should inspect the bar to make sure it is sitting flush against the saw.
Nov 08, 2008 | Makita 5012B 12'' Electric Chain Saw
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
1,191 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
