Question about HP Office Equipment & Supplies
I'm getting horizontal streaking through the text. I clean the printer fairly regularly but the ink absorber pads seem to be disintegrating. Any way to replace these these. Oh yeah, the printer is a Hewlett Packard Deskjet 692c and otherwise, despite it's age, still works like a dream.
  • pointe2009 Mar 09, 2009
    It helped a bit but to be honest, the inside of the printer wasn't really dusty. The streaking is less but not completely gone.
  • 24 Answers
Friend,
Am I right when I say that this mostly happens when printing in black? If so, there seems to be a lot of dust under the carriage and printheads. This has to be removed physically, cannot be fixed by running the cleaning program in the printer driver. If you open the lid the carriage should come out to the middle. If so, please pull the printer's power cable from the wall and wait until all lights are out on the printer.
Proceed to remove the printheads from the carriage, and use a lint-free cloth wetted with clean and luke warm water (it should NOT drip!) to clean the underside of the carriage, all the way round. Also clean the printheads, avoiding to touch the silver/golden colored chip in the middle, where the ink is ejected. My qualified guess is that you'll wipe off a lot of dirt from these areas.
Also, there's a small grey/transparent plastic strip in the back of the printer, called an encoder strip. This also gets dirty and needs to be cleaned. You should use the same type cloth for this, just make sure that no water can drip into your printer.
When you look lcosely, you'll see that this encoder strip is firmly attached in one side of the printer (usually the right side), and attached to a blade spring on the left side. Now you should carefully pull the rag over both sides of the strip TOWARDS THE SPRING, pulling the other way will most likely make the strip jump off and hang loose in the printer - not supported... :) You'll probably be amazed how much dirt this printer has accumulated over teh years.
When all is clean, insert the printheads again and power up the printer. When closing the lid, the printer should go back to normal duty. And, as a bonus, your printer will most likely be a little more quiet, less slamming noises than it had before you started.
Hope this solves your problem.
//Al
Posted on Mar 08, 2009
,Printout has white horizontal streaks using win10 or my mini iPad, printer ok using Apple computer, while printing text. Color cart. Showing low ink, but was just replaced
When the ink is run past low (to empty) the print head can get damaged. You can also try 2 consecutive DEEP CLEANINGs .. See 'maintenance' in printer driver under advance setting
s
Jan 06, 2018 | Apple Office Equipment & Supplies
Horizontal White Lines
My 1st thought would be clean heads also. If ink is tanks only not heads take ink out and try cleaning heads with liquid cleaner available @ Staples or similar stores. Another fix might be to use alignment utility for your printers software; however before you do any of this if ink is old or nearly empty replace ink.
Jun 13, 2013 | HP OfficeJet V40 All-In-One InkJet Printer
Pink and blue streaks on right side of page
most probably your "soak" pad need exchange. check your manual and change it. when you "deep clean" heaps of ink is absorbed into the pad exacerbating the problem, not solving it.
remove cartridges first and check them for existence of any foreign matter,
check for presence of debris under the head and parking place, remove if any,
i would suggest cleaning of printheads, albeit this can be risky (check first if your ink is soluble in water, isopropyl alcohol or methylated spirit, use that which solve your ink without clumping as cleaning agent), remove cartridges and allow appriopriate solvent to sit few second on metal rasters, wipe them with clean absorbing tissue and repeat procedure till solvent is "sinking" through the net.
remove old and install new absorbent pad under the print heads,
re-install inks, print rest page and then "normal" page. ink on first test page maybe very weak as solvent need to go through first.
if you follow the steps correctly, your should have clean print on the end.
"deep cleaning" is just waste of time, effort and ink. it is better if you create yourself a document with alternative lines of all three basic colours and black and then print it.
Jul 26, 2010 | Canon PIXMA MP780 All-In-One InkJet...
MP 610 is leaving black ink streaks the length of the page on back of paper. I have used the printer maintenance to clean the rollers, ink head etc several times and have installed a new black ink...
That sounds like the ink is coming off the waste ink absorbers. Try blotting the excess ink off the bottom of the printer with paper towels. The ink absorbers are small pads at the bottom of the paper feed path. With work, you can pull them pads and rinse them clean and then reinstall them when dry. Unfortunately, this can take almost disassembling the printer. Simply absorbing some of the excess is a temporary step.
I hope this helps.
(there is a counter that indicates when (based on average use) the waste ink absorber is full. The printer will stop working when that number is reached. Unfortunately, I haven't seen a reset for this model that actually works.)
May 17, 2010 | Canon MP610 Photo All-In-One Printer
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
My brother mfc 440cn read unable to clean error46
Its Ink Absorber Box is full. Inside the machine, in the back and hidden under the covers is a large plastic box with thick, felt pads packed in it. Every time the machine cleans its printheads, it squirts ink through all its nozzles, collects the mess, and pumps it into that box. After a few thousand cleaning operations, it decides the box is dangerously full of ink and throws up that Error 46.
Getting to the Ink Absorber Box (part number LP1270001) is fairly complex. I think it's time to ask a tech what he/she charges.
Jun 05, 2009 | Brother MFC 420CN All-In-One InkJet...
Cleanilng ink absorber pads
boil them till the ink starts coming out then rinse and repeat if nessisary "DO NOT OVER BOIL"
Mar 27, 2009 | Epson Stylus RX580 InkJet Photo Printer
Pictures with horizontal lines
I'm assuming the horizontal lines you're gtting are dark lines, not white omission lines and you are not currently using a cartridge that is leaking (otherwise, this solution is not appropriate). I had the same problem, and after a good deal of frustrating experimentation, found that the problem was caused by the cartridges picking up and retaining ink left on the little absorption pads where they rest. Normally, the pads should accomplish just the opposite effect, but it seems that after a certain amount of use (especially if you've ever had a defective, leaky cartridge), the pads just get too full. As the cartridge moves horizontally across your paper, ink picked up from these pads literally drips on your print. Could appear as lines and also as small smudge dots at the lengthwise travel stops where the cartridge travel reverses.
I could see that it would be fairly easy to remove the pads and either clean or replace them if I were to disassemble the housing of the printer. If you wish to do a really thorough job and you feel confident in your reassembly ability, go for it. I chose a quicker approach and it's solved the problem for the past two months: Open the lid and wait for the cartridges to move over to the left (cartridge replacement position). Then, pull the plug on your printer (or they will move back to the right after a few minutes). Use a small flashlight to locate the two absorbent pads over on the right, where the cartridges normally rest. With paper towels or any other absorbent disposable, blot those pads over and over until you get little or no ink on your paper towel. While you're at it, give the whole area under the lid a decent but gentle cleaning using a soft cloth or swab. Might take a couple of prints to completely eliminate the lines, since you won't be able to clean the underside of the cartridge carrier assembly this way, but this should solve your problem
Nov 19, 2007 | Canon PIXMA MP150 All-In-One InkJet...
100 people viewed this question
Ben Johnson
