Question about Toto CST414M-11 Aquia Dual Flush Elongated Toilet - Colonial White
I have a toto toilet. After flushing it is taking a very long time to fill up.
  • 659 Answers
Make sure that the fill valve doesn't have debris caught inside near the valve needle. Also the tube that attaches onto the flush valve can become clogged near the fill valve as well. Remove the hose and then take a needle and try and clear the outlet. Blow through the tube to insure that it's not blocked as well.
Posted on Mar 19, 2009
How do I get the water to stop filling the tank on my toto ST794S toilet?
there should be a screw adjustment on the ballcock or fill assembly...screw that down some to adjust...that regulates your tank water level....that screw goes in or out to or other should do the trick...may have to do this a few times to get proper adjustment...good luck..
Jul 07, 2014 | Toto St794s-12 Nexus Tank With G-max...
Toto toilet won't flush
Replace the assembly. This is common in areas with high mineral content in water. You will be glad you did. Delay too long, you may find your toilet running while you are at work .
Jan 25, 2013 | Toto Drake ADA Compliant Toilet with...
Toto neorest 500 take two flushes to work properly
Water pressure may not be strong enough or the tank is not filling up well in the back.does it have trouble on just flushing urine.
Jan 13, 2013 | Toto - Toilet - One-piece - Neorest 500 -...
I have a toto toilet that doesn't start to refill until a couple of minutes after I flush. Any ideas. Thanks.
Several ideas. Start to fill? Have you looked inside the tank to see what's going on? If it just filling very slowly, then you most likely have some calcuim build up inside your flush valve blocking some flow, if this is the case you will have to clean the flush valve. If your flush valve is staying up and the toilet is "running" unitil the float drops. The float (either the arm ballcock style, or newer fluidmaster) is rubbing on either the flush lever or side of the tank, and taking longer to drop to let the water start flowing. I
Jun 23, 2010 | Toto Toilets ST784S 12 Sedona Beige...
Hello, we have a dual flush toto and since installation we've had a problem with the water filling up after a flush. every single time i have to take the cover off and twist the flush valve (the part on...
check the water supply tube.remove and check to see if any blockage is present.either remove completely and blow through it,or just remove top of tube and inspect it.this has happened to me various time's.possible solution.
Apr 16, 2010 | Toto Aquia II Dual Flush Toilet
Toto toilet
check the pipe connection from water tank
Mar 17, 2010 | Toto Washlet S400 for Power Gravity...
Flush problem with toto toilet
If your hooked to city water it can be cause of the high water pressure comes across and keeps flapper from seating rite. Take a empty plastic bottle,cut it in half long ways. flush toilet then place plastic bottle between fill valve and flapper,trying to devert water away from where flapper seats. good luck.
Jul 23, 2009 | Toto Dartmouth 2pc. E/F Toilet ...
Toto toilet with gmax flushing system blue top
I have the same problem and can not find a solution. The toilet flushes fine but then a delay in filling up the tank occurs. Is there a part I can replace? Does something need to be cleaned or cleared?
Jun 20, 2009 | Toto Drake ADA Compliant Toilet with...
Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Mar 07, 2009 | Toto Aquia II Dual Flush Toilet
Toto CST414M-11 Aquia Dual Flush Elongated Toilet - Colonial White  Logo
320 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
