Question about Jenn-Air WW27430P Stainless Steel Electric Double Oven
No lights on panel can't read temp. or time how to replace lig
How can I replace lights,,can i get light and do it myself or do i need technician is there a web site that gives instruction on this repair?
    Scholar:
  • 54 Answers
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by BrianGem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF. DISCONNECT OR TURN OFF POWER PRIOR TO ANY REPAIRS.
Posted on Aug 12, 2009
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
It won't get to temp, then it beeps and it says f9...it continues to beep, and inside light is off
Disconnect power to the oven.
Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation. Repair wires as needed if defects are present.
Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
Contact a certified GE appliance repair facility if the source of the F9 code has not been discovered. Troubleshooting the oven with the electric power turned on is a job for a certified technician.
Mar 05, 2010 | GE Monogram® ZET3038 Dual Single Oven
AEG OVEN FAN WORKS TEMP LIGHT SOMETIMES NO HEAT IS
If the fan and light are working it points to a faulty heating element.
However the only sure way is to test both with a multimeter.
With the power off, check the element for resistance (ohms) if there is no reading the element is open circuit i.e failed and will need to be replaced.
I you are getting any reading on the element, it should be ok.
Then check the thermostat circuit out with the 'stat 'on,' again if no reading the 'stat is faulty.
Jan 24, 2010 | Electrolux Ovens
Gas oven not keeping temp consistant
Hi. this is a failing oven temp sensor. the sensor probe is not responding to the oven control. this will cause erratic temps in this oven. it will also damage the control board if the sensor isn't replaced soon.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
LCD display is blank , won't light up at all?
I had the same problem, mine faded out over time until I couldn't read it anymore. I had to have the circuit board replaced. The technician said that over time voltage surges can burn them out. It used to be frequent that I'd come home and all the clocks needed to be reset, so I know my area does have power problems.
The board comes out rather simply, I'd do it myself if if ever happened again.
Feb 10, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Nov 16, 2008 | Thermador SMW272 Electric Double Oven
Front display does not light up
I experienced the same problem. Order a control panel piece and replace it (the clock panel -is what it is referred to on parts list). It is a matter of killing the electrical power, unscrewing the contro panel, unplugging the old panel and plugging in new panel. Takes all of 8 minutes to do. I am a woman and did it myself. Got tired of waiting for the man to do it. Lived with the old panel for about 4 months before deciding to handle it. I found the control panel on line for $146. Appliance repair shops quoted $300 and more to do it - telling me the part itself would cost $275. Save yourself some money and the installation was very easy.
Apr 19, 2008 | Jenn-Air JJW8630C Expressions Collection...
Light for the temp. & time very hard to see can it be made brighter?
then you will have to replace the eoc the electronic oven control as long as it was working id use it till it wasnt then replace it
Jan 19, 2008 | Jenn-Air JJW8530C Expressions Collection...
Display Panel Light
There is a replacement display assembly, i think its around $150-$200. Its pretty easy to change if you are at all mechanically inclined. Good Luck!
Oct 29, 2006 | Jenn-Air W30400P Stainless Steel Electric...
Jenn-Air WW27430P Stainless Steel Electric Double Oven Logo
257 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
