Question about Sony Playstation 3 (PS3) Console
Ps3 to gateway fdp1760 frequency out of range dvi to hdmi cable
Setup: Gateway fdp1760, PS3, and one HDMI to DVI cable. Monitor works fine with computer. Monitor supports High Definition DVI input. I set my PS3 display to 720 only with no superwhite support and limited rgb.(in other words simple 720 with no frills). When I plug my ps3 to my monitor, I get a black screen or a message that says frequency out of range. What gives?
  • kaotyk Mar 08, 2009
    Nevermind. it seems that even though I have a dvi input on my pc monitor and I use a dvi to hdmi cable for the ps3, if the monitor I want to use is not hdcp (high definition copyright protection) compliant then it won't work with the ps3. I guess i solved my own question.
    Champion:
  • 241 Answers
What Frequency is the monitor set to run at ? u will get that mesg whan the monitor is receiving a signal that is greater than what it can handle say ur monitor can take 1024x768@60hz from ur PC and maybee ur PS3 is sending 720x720@100hz so ur monitor can handle the resolution but not the refresh rate that would be why u get that message
Posted on Mar 24, 2010
Help Adding a 2nd Monitor to ALL-IN-ONE
Try using a VGA to VGA cable or a dvi to dvi cable because dvi-d and hdmi tend to lack the necessary pins to be converted to an analogue signal. A hdmi to dvi cable may also work
Jun 12, 2013 | Gateway One ZX4970G-UW308 All-In-One...
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
I have my PS3 hooked to the HDMI port, but the monitor won't switch inputs to the HDMI port. If I have something plugged into the dvi port it works fine, but I currently need only the HDMI port, and do...
There are a varity of HDMI cables, ensure that your version is supported also using the input touch "button" to change the input through VGA, DVI and HDMI.
damnor01
Nov 22, 2010 | Acer H233H bmid Monitor
"out of range" when connecting ps3 -> benq t221w
It display out off range because the PS3 is feeding the monitor with higher resolution that the monitor cannot suppoert, try setting the PS3 to the lowest resolution first and go up from there.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | BenQ T221W Monitor
My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Jul 03, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Sony Playstation 3 (PS3) Console Logo
861 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
