Question about Singer Vacuums
Beater bar on singer central vac stops beating
Have cleaned and taken the beater bar (air driven) on my singer central vac apart several times... works for a short while and then beater bar stops working..
  • 125 Answers
Try cleaning the ends of the brush roller. thread gets caught in there and jams it
Posted on Mar 09, 2009
The beater bar is making a loud noise, and the dog hair is wrapping around the bar. Why would that be happening?
You probably have dirt or garbage wrapped around your beater bar. Loose carpet strings as well as pet hair will do this. If you see dog hair on the carpet its best to pick it up with your fingers as it will make a mess of a vac. Check your drive belt as it could be on its last legs as well causing the loud noise. Probably should be taken apart and belt replaced and a good cleaning as well. You should give a good cleaning once a year.
Nov 07, 2016 | Vacuums
I need a DIY solution because my shark navigator lift away beater bar attachment stops working intermittently
If you've gotten 4 years out of a Shark you've already beat the system. Give yourself a pat on the back, throw it in the nearest dumpster, then go to your local vac shop and purchase a quality USA made vacuum cleaner that is repairable and will likely last 20-30 years. Chinese vacs are designed to last one year and parts are not made for Sharks.
Jan 07, 2015 | Shark Navigator Lift-Away Upright Vacuum
I have an Eureka Altima Model 2961AVZ vacuum that suddenly stopped picking up. I have taken it apart, checked the belt which was fine, replaced the hepa filter, and checked for clogs in all the hoses
Is the beater bar actually turning when the power is turned on? Sometimes the belt is fine, but something is jammed and keeping the beater bar from turning. What about the section behind the beater bar, but before the hose upright. I've found large pieces of paper jammed in here and then hair gets caught, ultimately blocking the whole system. Usually you have to turn it over, remove some screws and disconnect the belt and beater bar to get underneath. Just reassemble it in the reverse order to how you took it apart. Double check the hoses and run a "unwound" metal coat hanger through to unclog anything. Does the vacuum " suck" with the hose or tube up to it disconnected? If not you may have a motor that somehow got junk pulled into it. You can open this up as well and clean this out. Of course unplug it all before doing anything.
Nov 03, 2014 | Vacuums
Beater bar on aerus electrolux ambassador canister vac has stopped working.
Beater bar failures are quite common in vacuums, Electrolux is no exception.
Apr 17, 2017 | Vacuums
Vacuum has been working great. Purchased in April of 2003. Yesterday, while vacuuming, it shut off so I left it off for 30 mins. It started up again fine but now when I vacuum the dirt cup doesn't...
Based on your description, your unit has an air flow blockage. The shutdown sounds like thermal protection. Something is blocked, somewhere. You have to verify that each and every inch of the air flow passageways are open.
Jul 12, 2011 | Vacuums
My vacuum lost it's suction power. I've looked to see if it's clogged and the container is clean. What's going on?
That type of vac is notorious for stopping up where the 90 degree turn is. You may need to access it from the vac head by removing the beater bar or take it apart where ever you can access the turns and hoses.
Feb 19, 2011 | Bissell Healthy Home HEPA Bagless Upright...
DC07 beater bar does not move
this is a common problem it moves on air flow, the air flow may be good but there is stuff wrapped around the ends of the beater bar, disassemble bottom of the unit and clean real good. it comes apart real easy :)
Oct 10, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vac won't turn on and the beater bar won't turn.
If you are having the same problem, then maybe there is something that you aren't doing right. But you do have a years warranty on what ever brand and model this is, take it in for warranty repair.
Jun 22, 2008 | Vacuums
Vacuums Logo
102 people viewed this question
Top Singer Vacuums Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a Singer Vacuum Expert? Answer questions, earn points and help others
