Question about Sceptre X32BV-Naga 32 in. LCD TV
TV loses power
Several times a day the tv just blacks out. the power lite goes out and the tv goes off. I have to uplug the tv 5 or 10 minutes and when I plug it back in it works until it does the samething the next time. Some days it will work fine all day. Some days it will shut off 5 or 6 times. Any suggestions?
  • 6,784 Answers
Hi, this is typical capacitor issues. they are failing to hold there charge load. they will eventually blow and render the tv useless. these are located on the power board. i suggest a repair in the near future.
Posted on Mar 07, 2009
Plasma tv randomly goes black
By the highly technical manner in which you set forth the problem, I can see you are far more electronically savy than am I, BUT just a thought: Is there there any sort of timer setting in the TV menu which may be cutting it on and/or off, and which you have somehow failed to notice? Good luck. . .
May 22, 2016 | LG 60PN5300 60" Plasma TV 1920x1080, 600...
My 55ld520 screen goes black, turn off for short time comes back on but then goes black again.
Start simple by using different cables, whether they be HDMI, VGA or standard COAX cables. They could be losing the connection. Also, it's possible the power supply is wearing out and it gets too hot. You might want to simply try some spray air duster type thing to clear out any dust that can make it hot.
Sep 20, 2014 | LG 55LH40 55 in. LCD HDTV
Bose sound not working and power is on
hello...........could be the mute botton on the remote .dirt might have have it stuck...lite brush w/ toothbrush or some keyboard airspray........tkx..............g.scott
Jun 08, 2014 | Bose Solo TV sound system - Black
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
TV stops video and audio for about 5 seconds
This model does have some issues, you can try on it to either remove it and a box if used for power for several minutes and then power back to see if that helps.
Soft reset with set on should (using original remote) be Menu, 1,2,3 and enter.
Dec 20, 2012 | Mitsubishi WD-73737 73 in. HD-Ready TV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
LG 47" LCD FLAT SCREEN
IF IT WASNT DIGITAL HD I WOULD HAVE SUSPECTED HIGH VOLTAGE POWER SUPPLY BUT THAT DOES NOT EXIST HERE.
Well, not completely true; the fluorescent backlight is still a high voltage device, even if only hundreds of volts instead of kilovolts, and either the lamp(s) or the power supply for it (them) is causing the dropout of your picture. When it does it next time, look at the screen from various angles, I think you will see that video content is still there.
Jun 05, 2008 | LG 47LC7DF 47 in. LCD HDTV
Sceptre X32BV-Naga 32 in. LCD TV Logo
633 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
