Question about Boss IQ 3KD.1 Car Audio Amplifier
Will my car stereo power 300 watt speakers?
I have dual 300 watt subs and I want to know if either a stock stereo from a 2001 chrysler sebring lxi or a stock stereo from a 1997 cadillac deville will power these speakers or do I positivley need an AMP?
  • Anonymous Apr 01, 2014
    chrysler sebring 2001
  • 55 Answers
It will power them but it will only push a small amount of wattage to them. something like 45 watts so they won't be very loud but if you run the wires you will hear them. It's beneficial to just invest in an amp you can pick up a 200 watt pretty cheap these days. and you will be much happier with the end result.
Posted on Mar 11, 2009
Everything works on my stereo system,but there is no sound
Car Stereo Head Unit Install ** No Sound ** Amp Not ...
? 10:41
https://www.youtube.com/watch?v=wQ9bSdJGMjg
Mar 23, 2014 - Uploaded by PSYCHOTICNORMAN
Video for those who installed their head unit correctly, but got no sound / factory amplifiers not turning on. ... Car Stereo Head Unit Install ** No Sound ** Amp Not Turning On ** work around. ....Did everything to the letter on a 2001 Chrysler Town and Country and while I do have audio, my audio is cutting in ...
Everything works on my stereo system,but there is no sound ...
www.fixya.com/.../t26059653-everything_works_stereo_system_but_no
1 hour ago - everything works on my stereo system,but there is no sound lxi 4cd canger - Chrysler 2001 Concorde question.
Chrysler Concorde radio works but no sound Questions ...
www.fixya.com > ... > Cars & Trucks > Chrysler
Chrysler Concorde cars & trucks radio works but no sound questions and answers. ... Fixya - Solutions for Everything ... My 2002 concord lxi when ... CAR STEREO HAS POWER BUT WILL NOT OPPERRATE ... Question about 2001 Concorde ... ...sound from radio thru speakers Is there any popping when playing a CD or ...
Jan 19, 2016 | 2001 Chrysler Concorde
I have 2 12" Pioneer TS-W3003D4 subs and I wanted to know can a Pioneer GM-D8500M run them?
pretty much any amplifier can run any sub, so the question is not weather or not the amp can run them, it is how well the amp can run them. Those Pioneer subs are dual VC models and are rated at 600 watts RMS. You have two, so that would be about 1200 watts of RMS power you will need in order to power the subs correctly and to optimum efficiency. The amplifier model you have is rated at 600 watts RMS for a single channel at the lowest stable impendence. That power coming from the amp will be split two ways between the subs and divide the power to each speaker. So each speaker will be receiving 300 watts of power. So in short yes, your amp will power those subs, but they will only be operating at half their rated power. Your amp will be running at maximum power so it might get a little warm after a while. make sure you wire it correctly and keep the amp well ventilated if you decide to push it that hard. if you need help on how to wire them search the web for wiring options by typing into Google " how to wire two dual voice coil subs into amp". There you will find plenty of illustrations to help you decide.
Aug 25, 2015 | Pioneer Car Audio & Video
I was given a subwoofer and box but do not know where to go from here in terms of hooking it up in my car. It is a Rockford fosgate punch p112s4.
First youll need an amp. Depending on what size the sub is a 500 watt rms amp can hold up to about a 300 watt kicker. If your looking for something bigger u can get a 1000 watt amp and hook up two 300 watt kickers. To hook up the amp youll need a car amp power cable, power control cable, speaker wire, amd a car amp ground wire. They usually sell kits that run aboyt 40 bucks. The power cable goes to the batter as well as the ground cable. The power control cable goes to the back of the head unit. (You will kost likely need a more modern headunit if urs is stock). Once this is done put the sub in the box (i recomend super glue because metal nails take away from the bass). Put the speaker wire to the speaker positive on left negative on right. Same with the amp. And now ur bumpin ;)
May 06, 2013 | Car Audio & Video
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
Need wiring diagram for stereo 1997 sebring
Hi there:
I suggest to check this on 1997 Chrysler Sebring Convertible Car Radio Wiring Guide...
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Black/Yellow
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Green/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2" Speakers
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Car Audio Rear Speakers Size: 6" x 9" Speakers
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Nov 07, 2012 | 1997 Chrysler Sebring
Tire specs for 2001 chrysler sebring
HI. Here is the complete line up of specs concerning your vehicles front and rear tires. You did not post the trim line of this car, so I posted all models and tire combination's specified by the manufacture.
2001 Chrysler Sebring Lim 2 Door Convertible Front and Rear Tires P205/60R16
2001 Chrysler Sebring LX 2 Door Convertible Front and Rear Tires P205/65R15
2001 Chrysler Sebring LX 2 Door Convertible Front and Rear Tires P205/60R16
2001 Chrysler Sebring LX 2 Door Coupe Front and Rear Tires P205/55R16
2001 Chrysler Sebring LX 4 Door Sedan Front and Rear Tires P205/65R15
2001 Chrysler Sebring LX 4 Door Sedan Front and Rear Tires P205/60R16
2001 Chrysler Sebring LXi 2 Door Convertible Front and Rear Tires P205/60R16
2001 Chrysler Sebring LXi 2 Door Coupe Front and Rear Tires P215/50R17
2001 Chrysler Sebring LXi 4 Door Sedan Front and Rear Tires P205/60R16
Jul 06, 2010 | 2001 Chrysler Sebring
Can you tell me what lxi stands for on a 2001 chrysler sebring convertible please
LXI - L stands for Base Model and XI stands for Petrol.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 01, 2009 | 2001 Chrysler Sebring
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Boss IQ 3KD.1 Car Audio Amplifier Logo
188 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
