Metrocab london taxi converted to lpg with a ford galaxy 2.3 ohv petrol,keeps cutting out on gas and petrol but is intermittent,starts again first time also starts missfiring and losing power,then seems to clear itself.Could it be faulty sensors?
SOURCE: xj6 3.2 1994 lpg
if you use lp and loose power it is a problem with the lp regualter, this acts the same way as a fuel pressure regulater on a fuel injected vehicle. you need to have this replaced. please rate this thanks
SOURCE: LPG probs
How close to the exhaust is the supply line as the lpg supply line should be cold until it gets into the regulator not warm.Is the supply line heat shielded as it enters the engine bay or getting a full dose of exhaust heat?Is it the vapor injection gas system or the old style.What regulator and system are you using?OMVL ?sprint gas or other cheaper variants?It really sounds like a fuel delivery issue as you are not getting the volume of gas required at higher speeds.Commodore engines have issues with thier water system having air bubbles that cause air locks in the regulators by the time youve jumped out of the car to check for freezing it appears to be fine.You may have restrictions in the lpgas filters/locks.The water hoses,2,should be hot so hot you cannot leave your hand on them and if not freezing of the reg once again becomes the issue.Also the water hoses must be fitted in such a way that the top hose is suction and the bottom hose forces water into the reg,this is done to assist in eliminating potential air lock problems.To sum up your symptoms are consistant with poor water ciculation.
SOURCE: My LPG gauge shows 2 leds but I can't run on gas?
FILL IT UP FIRST ...DONT TRUST THE LIGHTS MAY BE A SELONOID GONE AND NOT LETTING THE LPG THROUGH
SOURCE: started car running on petrol for 5 minutes with
could be number of problems but often this is caused by valve on the inlet manifold which is electricaly operated and then it allows the gas in but it is also vacumn sensitive so a perished rubber pipe could cause it not to sense the vacumn .best advice without seeing it is to visit a mechanic that is conversant with LPG conversion
Testimonial: "Have already booked in with an LPG mechanic. Just wanted a bit of heads up so I knew what it might be. Many thanks for prompt response"
AerostarV6 - 3.0L vin U 182ci - MFI GAS OHV
7 vehicles
1986 - 1992
BroncoV8 - 5.0L vin N 302ci - MFI GAS OHV
2 vehicles
1986 - 1987
BroncoV8 - 5.8L vin H 351ci - 4BBL GAS OHV
5 vehicles
1988 - 1992
BroncoV8 - 5.8L vin H 351ci - MFI GAS OHV
5 vehicles
1987 - 1991
E-150 EconolineV8 - 5.0L vin N 302ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-150 EconolineV8 - 5.8L vin H 351ci - MFI GAS OHV
5 vehicles
1987 - 1991
E-150 Econoline Club WagonV8 - 5.0L vin N 302ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-150 Econoline Club WagonV8 - 5.8L vin H 351ci - MFI GAS OHV
5 vehicles
1987 - 1991
E-150 Econoline SuperV8 - 5.0L vin N 302ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-150 Econoline SuperV8 - 5.8L vin H 351ci - MFI GAS OHV
5 vehicles
1987 - 1991
E-250 EconolineV8 - 5.0L vin N 302ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-250 EconolineV8 - 5.8L vin H 351ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-250 Econoline Club WagonV8 - 5.8L vin H 351ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-250 Econoline Club WagonV8 - 7.5L vin G 460ci - MFI GAS OHV
1 vehicles
1991
E-250 Econoline HDV8 - 5.8L vin H 351ci - MFI GAS OHV
5 vehicles
1987 - 1991
E-250 Econoline SuperV8 - 5.0L vin N 302ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-250 Econoline SuperV8 - 5.8L vin H 351ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-350 EconolineV8 - 5.8L vin H 351ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-350 EconolineV8 - 7.5L vin G 460ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-350 Econoline SuperV8 - 5.8L vin H 351ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-350 Econoline SuperV8 - 7.5L vin G 460ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-350 Econoline Super WagonV8 - 5.8L vin H 351ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-350 Econoline Super WagonV8 - 7.5L vin G 460ci - MFI GAS OHV
6 vehicles
1988 - 1994*
F Super DutyV8 - 7.5L vin G 460ci - MFI GAS OHV
7 vehicles
1986 - 1992
F-150V8 - 5.0L vin N 302ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-150V8 - 5.8L vin H 351ci - 4BBL GAS OHV
5 vehicles
1988 - 1992
F-150V8 - 5.8L vin H 351ci - MFI GAS OHV
7 vehicles
1986 - 1992
F-150 Super CabV8 - 5.0L vin N 302ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-150 Super CabV8 - 5.8L vin H 351ci - 4BBL GAS OHV
5 vehicles
1988 - 1992
F-150 Super CabV8 - 5.8L vin H 351ci - MFI GAS OHV
7 vehicles
1986 - 1992
F-250V8 - 5.0L vin N 302ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-250V8 - 5.8L vin H 351ci - 4BBL GAS OHV
5 vehicles
1988 - 1992
F-250V8 - 5.8L vin H 351ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-250V8 - 6.9L vin 1 420ci - MFI DIESEL OHV
2 vehicles
1988 - 1989
F-250V8 - 7.3L vin M 445ci - MFI DIESEL OHV
7 vehicles
1988 - 1994
F-250V8 - 7.5L vin G 460ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-250 Super CabV8 - 5.8L vin H 351ci - 4BBL GAS OHV
5 vehicles
1988 - 1992
F-250 Super CabV8 - 5.8L vin H 351ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-250 Super CabV8 - 6.9L vin 1 420ci - MFI DIESEL OHV
2 vehicles
1988 - 1989
F-250 Super CabV8 - 7.3L vin M 445ci - MFI DIESEL OHV
7 vehicles
1988 - 1994
F-250 Super CabV8 - 7.5L vin G 460ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-350V8 - 5.8L vin H 351ci - 4BBL GAS OHV
5 vehicles
1988 - 1992
F-350V8 - 5.8L vin H 351ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-350V8 - 6.9L vin 1 420ci - MFI DIESEL OHV
2 vehicles
1988 - 1989
F-350V8 - 7.3L vin M 445ci - MFI DIESEL OHV
7 vehicles
1988 - 1994
F-350V8 - 7.5L vin G 460ci - MFI GAS OHV
2 vehicles
1988 - 1989
F-350 Super CabV8 - 7.3L vin M 445ci - MFI DIESEL OHV
7 vehicles
1988 - 1994
F-350 Super CabV8 - 7.5L vin G 460ci - MFI GAS OHV
7 vehicles
1988 - 1994
F53V8 - 7.5L vin G 460ci - MFI GAS OHV
2 vehicles
1988 - 1989
F59V8 - 7.3L vin M 445ci - MFI DIESEL OHV
1 vehicles
1991
RangerV6 - 3.0L vin U 182ci - MFI GAS OHV
1 vehicles
1991
Ranger SuperV6 - 3.0L vin U 182ci - MFI GAS OHV
