Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Poulan leaf blower won't start
I have a Poulan leaf blower, maybe two seasons old, not used much. Last time I used it, it ran fine. Turned it off and put it away for about a month. When I tried to crank it, it won't start. I sprayed starting fluid in the carburetor and it starts, runs for a few seconds and dies. Therefore, it is apparently getting a spark but not fuel. Pulled fuel filter out of the gas tank and blew through it. Put it back in the gast tank. Still won't start. What now?
  • 1 more comment
  • hooty59 Mar 08, 2009
    I have a similar problem and went down the path of adjusting the carburetor while it was running. Now I can not get it to start cold. What are the recomended carburetor settings for this unit.
  • Anonymous Mar 19, 2009
    ran good for 1yr now it wont run at all. no carb adj tool available.not a poulan but snapper is identicle same manufacturer
  • hooty59 May 11, 2010
    Opps wrong poulan leaf blower model...i have a ppb430vs.
2 Suggested Answers
mickey813
  • 472 Answers
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
Poulan pro bvm200vs
Take off the muffler and you should see the piston and ring..with a small pick push at ring to see if it moves. If no movement, you have carbon buildup from too much oil in fuel. Remove cylinder and carefully try to free the ring.
Jul 13, 2013 | Garden
Weed eater fb25 won't start
This blower is fuel sensitive! Gas and oil mixture has to be correct. Too much oil will cause carbon buildup in the cylinder. In my case my blower would not start after several uses this season. I checked EVERYTHING....spark, fuel delivery, air filter.....then checked the flywheel which has no separate key....the key is cast into the flywheel. Read somewhere about the carbon buildup so took the cylinder off and viola! The piston ring was firmly stuck in the piston groove plus the cylinder was carbon scored. I tried to gently pry the piston ring free but it was so firmly stuck, it broke. Not worth fixing. Take the muffler off and you will be able to see the piston ring....use a small pick or something to see if the ring is free. If not, proceed to tear down or throw out. I was able to see scoring on the piston and determine my ring was stuck this way. Remember the elements needed for successful ignition...fuel/air...spark....compression. Stuck ring = low compression. The last time you ran the blower the ring became stuck...the engine continued to run because of the engine rpm's but when you try to start at low RPM's, no luck.
Jan 18, 2012 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
It only runs for about 5 minutes at a time.
The ignition module is going bad. Cost of replacing part is more costly than buying a new blower.
Good Day.
Oct 30, 2009 | Poulan Featherlite Gas Blower, with Low...
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Yardbroom II pull start hard to pull
put a teaspoon of mix oil into the spark plug hole, some times the metal starts to bind in the engine. keep the wire off and the plug in and pull the cord a bunch of times until it starts to get easier, if you need to add more mix directly to the hole then do it. hope this helps
Mar 28, 2009 | Homelite 'Yard Broom' Leaf Blower
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
2,408 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
