Question about Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531
My freezer sounds like its on, but it wont freez. I took off the cover, and the coils look clean. The black thing, I think, is the compresor is realy worm. None of the copper coils are cold.I don't know if they should be. Is their a fuse or somthing i can change, or can i change out the compresor, if thats whal that black thing is or is it cheeper to buy a new freezer. because I think I can change it my self. Also i shook the black thing and it sounds like their is a ball in it. and the ligh dont turn on ether please help!!!!!!!!
  • 410 Answers
If the compressor is warm that is an indication to me that it is running or at least trying to run. if its running you should feel it vibrating as well as being warm. assuming the compressor is running and it's not cooling I would say you probably have a refrigerant leak and would come out cheaper to replace the unit. repalceing the compressor also is fairly expensive in exess of 300-400 dollars. Let me know if you have any other questions Peyton
Posted on Mar 08, 2009
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Why wont my freezer wont freeze everything else does
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Air needs to circulate in both parts (dependent on eachother)
Aug 29, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Why wont the freezer freeze?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 08, 2010 | Kenmore Freezers
Working on a t49 freezer it wont go below 30 , change compressor couple months a go worked fine. Now i change dry and regas with 22oz 404 and wont go down , my high side is 200 my low side is 18 . clean...
Sounds like a restriction to me.
Recover the charge.
Pressurize the system with 350 pounds of nitrogen pressure through the high side.
Leave it pressurized for 15 minutes.
Release the pressure through the low side.
Replace the filter drier again.
Pull a 2 hour vacuum on high and low side.
Recharge liquid refrigerant on the high side.
Let the system sit idle for 30 minutes before starting.
Check the evaporator fan motor as well as the coils. Use a good coil cleaner on the e-coil.
Jul 24, 2010 | Freezers
Freezer motor clicks on but then clicks right off again
Make sure the condenser coil is clean and the fan works (if not replace it) If those are ok probably the compresor relay is bad (no more than $30) and after you replaced the relay ,if still the compresor won't start the problem is the compressor itself.
Aug 27, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
My kenmore freezer is making a lous noise that
Is it still cooling ok - or is it going a bit weird ?
It could be the flow control solenoid - that affects where the gas goes - or the compresor motor (big black thing).
If it does not cool at all - it will need a new run capacitor on the compressor.
If it seems to cool ok - but sometimes too much - then suspect the solenoid coil / control for this.
Neither are that expensive.
Aug 07, 2009 | Freezers
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Freezer FF20DSERWH
IF THE FROST ON THE EVAPORATOR ISN'T ACROSS ALL OF THE COILS, THERE IS A PROBLEM WITH THE SEALED SYSTEM. NORMAL OPERATING TEMP IS ZERO DEGREES FAHRENHEIT. THE FROST ON THE EVAPORATOR SHOULD BE THIN AND UNIFORM. IF IT IS HAIRY AND ONLY COVERING PART OF THE COILS, THEN YOU HAVE A SYSTEM FAILURE. IT COULD BE A LEAK AND LOSS OF FREON, A RESTRICTION, OR A WEAK COMPRESSOR.
Apr 03, 2008 | Freezers
TRUE under counter FREEZER TU2-27F
Are both evaporator fan and condensor fan running?You stated that you topped off the charge.Assuming the charge is ok, the next thing to check would be the expansion valve.May not be metering the freon properly.A faulty expansion valve can trick you into thinking the unit is undercharged.It may be partially open and starving the evaporator.(Not freezing the water totally)You should have a even coating of frost on the evaporator coil when running.Hope this helps,let me know if i can assist you any further.
Dec 10, 2007 | True 12 cu. ft. / 340 liter Commercial...
Indesit Fridge Freezer
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing (by compressor), Check recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting, YOU CAN TRY turning FREEZER CONTROL To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side
Sep 08, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531 Logo
189 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
