Question about RTO Ariston Gl4.0 Instantaneous Electronic Water Heaters
Someone gave me an RTO Ariston Gl4.0 Instantaneous Electronic Water Heater, I installed it in my shop. I only seem to get whatever is in the tank and it's only warm. The warm water quickly turns cold so, the on-demand part is not working or not working very well, any ideas?
  • standbymex2 Mar 15, 2009
    I appreciate you trying to help me with this problem, but your answer seems 'cut short', thanks again.
    Sergeant:
    Champion:
  • 234 Answers
Something is wrong with the power . You check the connecter and you will proabbly find only side is making.
Posted on Mar 15, 2009
  • Earnest Bowes Mar 15, 2009
    This heater is what I call a quick recover unit.If heat is not wire right it won't heat the fast enough.You said it only heat what in the tank.It has to have a thermostat and I would guess some type of relay or contacter to make the power to the elements.
Ariston water heater service center
Copy following link for Bosch Ariston water heater resources:
http://waterheatertimer.org/Ariston-water-heater-resources.html
You can fix this water heater yourself, or buy another under-counter water heater if tank is leaking because anode depleted.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Gene
Jul 29, 2013 | Water Heaters
I have a Ariston Pro TI water heater. I am getting a lot of rust/junk/green/black, particals in the hot water plugging my shower heads. How do if fix this problem? Thanks Tom
If problem is hot water side only, then water heater is suspect.
1) If water heater temperature is set above 140F, it causes minerals to dissolve out of water.
2) If water heater is exposed to minerals in water, like hard water, those minerals will gather at bottom of tank.
3) If anode rod is depleted, the metal tank will begin to rust.
4) Combination of problems listed above.
To fix these problems, flush tank and replace anode rod, and possibly install water softener, install water filter, and turn down temperature setting.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
http://waterheatertimer.org/Replace-anode-rod.html
Jul 11, 2011 | Bosch GL8Ti Ariston Pro Ti Electric...
Water does not heat. Electric plug is okay.
verrify elctic to the heating element if u have electric there then it is a blown element must have water in the water heater when it is on or it will blow an element every time old age and corrosin will cause an ellement to blow too or if there is no electrick it could be a bad thermostate check out this page for ording info http://boschhotwater.com/Default.aspx?tabid=668
Jan 14, 2011 | RTO Ariston Gl4.0 Instantaneous Electronic...
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Size and installation for instant water heater
Ariston gl4.0 should be fine if used inline with your hot water heater. Used alone it will likely run out when dishwasher is filling and you are using sink.To use your existing hot water for backup: 1 connect existing HOT water line to cold (inlet) on ariston, 2 Then HOT (outlet) from ariston to sink and dw. If you want instant hot water at a sink 10 feet away: use 3/8 pex pipe from ariston to sink, so you only have to run off a cupful or 2 before hot water arrives at sink.
Aug 30, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Not continuous hot water and radiators
If it has a distance from the boiler to your use the water in the lines and the lines themselves ahve to warm up before you will get hot water, Let me know more if this dosnt help. Please rate me as high as possible if it does help you understand your trouble.
May 31, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Morco F 11E tankless water heater Slight problem
One more thing ,they do make a valve call mixing valve.That's to mix the water hot,cold to a temp. you want.Most restranrest have them in the water lines at the restroom.They suspose to keep it around 110 deg.
Mar 18, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
RTO Ariston Gl4.0 Instantaneous Electronic Water Heaters Logo
123 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
