Question about Kodak EasyShare M1033 Digital Camera
Kodak M1033 will not turn on sometimes unless you remove and then replace the battery.
  • Anonymous Mar 29, 2009
    I have the same exact problem. This is my second camera. The first one had multiple problems (turning off right after turning on, blurry view) and I took it back in exchange for the same model. Same problem with the new one. Very frustrating
  • kipperedwhit Apr 03, 2009
    I had the same problem. Taking the battery was the only way I could fix it
When i turn my camera on it shuts off after 3 or 4 seconds and will not sray on
Posted on Mar 24, 2009
I have a Kodak M1033 HD. It will turn on but then shuts off immediately. I have replaced the battery and cleaned the lens with no results. Please help!!
go to : http://www.fixya.com/support/t5301378-kodak_m1033_lenses_stuck_open
i did it at it works now but you have to remove the front metal case(4 screws on teh sides) and blow the air
bonne chance
Aug 05, 2010 | Kodak EasyShare M1033 Digital Camera
My kodak easy share m1033 camera turns off when i press any button
there is dirt or sand in motorized lens turn camera on and pop battery out before lens goes back in. Use a lens cleaning cloth and wipe all the outside of the camera lens well I also use a can of air and blew the three rings of the lens.I had to do this two times but now the camera works great
Mar 23, 2010 | Kodak EasyShare M1033 Digital Camera
Kodak M1033 lens comes out but will not go back
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 22, 2009 | Kodak EasyShare M1033 Digital Camera
Have a kodak m1033 that seems to be frozen in the "off" mode. Have replaced the battery twice, works for a day or two then won't/can't charge and can't get the power light to come one even with the charger...
All Technical equiptment can have problems Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 19, 2009 | Kodak EasyShare M1033 Digital Camera
No flashing blue light when charging. Lens will not return into
Here are the steps:
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or possible alternative a new cable.
Contact KODAK:
Nov 28, 2009 | Kodak EasyShare M1033 Digital Camera
Kodak m1033 cameraturns on shows date and time have been reset camera buttons and controls do not function
Ii understand your problem description as the camera turns off immidietly after having shown the date and time.
Here are the steps:
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 25, 2009 | Kodak EasyShare M1033 Digital Camera ...
My M1033 will power on and then it just powers
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Nov 01, 2009 | Kodak EasyShare M1033 Digital Camera
Its turns on beeps then shuts off
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 05, 2009 | Kodak EasyShare M1033 - black Digital...
Kodak M1033 shuts off
Aug 03, 2009 | Kodak EasyShare M1033 Digital Camera
My kodak md1063 won;t turn on
replace rechargable batteries with regular AA alkaline and see if it will turn on, if it will you need a new battery pack
Jun 21, 2009 | Kodak EasyShare M1033 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
505 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
