Question about LG Chocolate Clamshell VX8600 Cellular Phone
Inside screen display is split
The inside screen display is like split in half some info on the right side and some on the left i took battery out and put back in then did a *288 phone update and it seemed to be ok. had to power phone down later and it was all messed up again. Tried the same process again and the screen seemed ok except now at the bottom of the screen where it says "message" (on the left) and "contacts" (on the right)....they have switched!!! The functionality of the softkey is the same but the words switched. Again did the same process of battery removal and update and now the screen info is split and the words are still switched. Phone is a few years old and no warrenty or insurance. Anybody heard of this or have any ideas for a fix?
Kisen p83 software driver
Posted on Mar 07, 2009
Split screen left side magnified right side regular how to quit?
Which version of OSX are you running?
Check in System Preferences under the Apple menu, then click on Accessibility and un-check the Zoom feature.
Also check Displays in System Preferences as well.
Oct 17, 2012 | Apple iMac Desktop
Half screen
Hi, You might have it in split screen mode. Go to menu and look for something that will make your screen normal again. Good luck.
May 30, 2012 | Sanyo Televison & Video
Left side white. its like the whole screen has shifted to the right
The lcd convertor went out. You can get them on Ebay for a few bucks.
Dec 21, 2011 | Computers & Internet
How to change from military time back to regular time on a digital indigo watch with 4 adjustment buttons?
Thank you for contacting FixYa.<br /> <ol id="ecxintelliTxt"> <li id="ecxjsArticleStep1"> Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.<br /></li> <li id="ecxjsArticleStep2"> Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.<br /></li> <li id="ecxjsArticleStep3"> Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.<br /></li> <li id="ecxjsArticleStep4"> Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.<br /></li> <li id="ecxjsArticleStep5"> Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.<br /></li></ol> Contact TIMEX for further assistance at:<br /> http://www.timex.com/info/Product_Instruction_Guides_Downloads
Aug 25, 2010 | Timex 1440 Nylon watch
Why have i only got half a screen
The calculator can be split in two. This is done by selecting certain MODE options as shown on the line that starts with FULL
In the Full option the screen is complete (regular screen configuration)
If you highlight HORIZ and press ENTER the screen will be split HORIZontally as
The upper part is for any graph and the lower part for the main calculator screen
Similarly, if you highlight G-T and press Enter, the left part of the screen displays the Graph screen and the right part the Table screen.
These are the normal instance where the screen of a Ti8*Plus is split in two.
Do you recognize any of these?. If you do just select Option Full in MODE screen to restore the full screen. If you do not, then I have no idea why you only have half a screen.
Aug 01, 2010 | Texas Instruments TI-84 Plus Silver...
Half of screen is green, split down the middle with the other side remaining normal. We have a Wii. HELP! Bought it at Circuit City, and they are gone...........
I never repair Vizio but I am sure this is the cause if this occurs on all video sources; WiI, TV tuner, etc.
LCD panel has 2 flat cables attached to the glass OR the board that attaches to the glass.
remove and reinsert this cable. Just know that if you open the TV you will probably see these cable easily....they will be at the upper middle portion of the back of the TV(inside of course)
There is 1 cable for the left side of the picture and another cable for the right. If the right becomes loose it affect right side of pictur and left cable left side.
Jul 10, 2009 | Vizio VU32L 32 in. HDTV LCD
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
AKAI LCT2662N screen problems -distorted
that sounds like your LCD controller, since the LCD screen is so big, they will "split" the screen into 2 smaller screens, otherwise it would be so outrageously expensive to have one big massive lcd controller. Your lcd controller is most likely a two-in-one card though, meaning that there are 2 controllers on one board. You'll more than likely need a new controller card for your tv.
Feb 20, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Display screen turn half black
hi there
you need to replace the screen because that means that you liquid matrix display ( LCD ) is already busted.
hope this helps.
Jan 29, 2008 | Cell Phones
LG Chocolate Clamshell VX8600 Cellular Phone Logo
89 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
