We have a crack in one of the corners of the screen and this is not stopping him from doing certain things on the tablet ie switching back a screen and we are having to overide the system? ive tried looking for a repair center but am not having any look. Help please
SOURCE: how to repair a toshiba portege laptop m205-s810 screen and where to get one
http://www.cuzwesaidso.com/archives/000773.html
the screen mask is what is cracked.
SOURCE: touch screen and digital finger scan's not working
there is one option that you have tak back-up your data then run recovery disk that is only solution becoz touch screen and finger print software is realy delicate things dont try to paly with if don't have to downlod drivers from the HP site
SOURCE: iPad replace broken screen
the only thing that i can be sure that would help is that you need to call the manufacturer and get a screen replacement because since the ipad is fairly new it wont have many guides or anything that can really fix a broken screen.
i hope that this can be useful
SOURCE: i got a crack on the screen of my hp tablet
the same thing happened to mine, and i thought i was out a laptop because i couldnt afford the repairs. after it had been sitting a while i figured i had nothing to lose by operating on it. i followed the hp service manual to remove the display panel, then took that apart. the screws are trickily hidden behind rubber stickers that blend into the plastic. i removed the frame, lifted the plastic cover, then carefully removed the broken glass pieces. i thought i was compromising the tablet pc features when i tore the glued perimeter of the glass. i figured a regular laptop was better than no laptop. be careful not to tear the tab attached to the copper piece on the side of the screen. also be gentle with the lcd screen. when i put it back together, i was amazed, but the touchscreen was still intact - it must be a component behind the lcd screen. i plan on replacing the glass with plexiglass to prevent another mishap, but i thought id share that this problem can be solved free of charge in just a few careful hours. good luck!
Senua Tablet Screen Repairs PCLiverpool.co.uk
