Question about Emerson SA-100 Car Subwoofer
Are these speakers any good?
Emerson SA-100 Car Subwoofer i have a friend that says he can get me a pair of them but iv never heard of them so i was wondering if they are any good
  • 55 Answers
These would make great secondary subs if your going for an elaborate install, but in the end even cheap no name subs will sound good if coupled to a good amp. The best way to know is to test them, push on the cone and feel it's resistence, if it feels tight, they should pound, if not, be careful.
Posted on Mar 09, 2009
Rear speakers on my 02 chevy Malibu not working don't know why iv tryed everything when I bought the car it worked and then out of nowhere it stoped working
If the radio fader is adjusted fully to the rear and there is no sound the speakers and wiring should be tested.
Best way of testing is to remove the radio to access the wiring to the speakers. Identify the pairs of wires to the rear speakers and apply a 9 volt battery to each pair. If the speakers and wiring are good they will make some noise and the fault will be either the connection to the radio or the radio is defective.
If no noise is heard when applying the voltage, the rear speakers should be accessed, disconnected and tested in the same way. If you have noise it is the wiring at fault. If no noise the speakers are faulty.
The result of testing can be verified at every stage by using a known good speaker and a couple of micro jumper cables.
Feb 25, 2017 | 2002 Chevrolet Malibu
What cord do I need to hook subwoofer up
You need the power cord that should already be attached, plus a single RCA patch cord to connect to your source. You could use just one of a typical RCA pair, if that's all you have.
Nov 18, 2013 | Sony SA-WMSP1 Subwoofer Speaker
Is the subwoofer from the Bose acoustimass 10 series IV Home Entertainment Speaker System a power sub?
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
Dec 09, 2010 | Bose Acoustimass 10 Series IV Home...
It is rip in to little piecies
It may not be worth the expense, but if the cone or surround are torn, they can be replaced by a speaker repair shop. I just had a pair of JL 10W6's re-edged (the foam surround around the cone deteriorated after 11 years), and the repair cost $100 for the pair, including parts.
Nov 01, 2010 | Thump TBB102 Car Subwoofer
Won't Sync with the Subwoofer
i can't get mine to pair ... has it paired for you? thx
Jun 06, 2009 | Philips DC912/37 iPod Docking Shelf Bar...
Its making a vibrating sond
It sounds like your amp may be adjusted to high, turn your gain down to a maximum of 3/4 of the way up. If its not loud enough at that setting you may need a bigger amp.
Jun 01, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Very little sound
make sure all your gains are turned up to atleast half.
Check your head unit, make sure your low pass frequency for the RCA's amp is set to high or set to more than 0. Make sure you don't have your fader set toward the front of the vehicle or you won't get any bass, but the subwoofer will be pulling only what the head unit is sending to the amplifier.
if that doesn't work I would try another pair of patch cables.
Do you have another subwoofer you can swap out to test your subwoofer with?
I have a subwoofer that has something wrong with the coil itself. Has your amplifier blown any fuses? If so the subwoofer coil is bad.
Also make sure you have a solid ground for your amplifier.
Hope this helps!
Apr 22, 2009 | Jl Audio 13W7 Car Subwoofer
Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Dec 28, 2008 | Harman Kardon HK695 Computer Speakers
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Sub doesnt sound loud
try to change subs with your friend to find out if the problem is on amplifier or on sub wofer
Nov 21, 2007 | Q-Logic QLT-.3508SS Car Subwoofer
Emerson SA-100 Car Subwoofer Logo
56 people viewed this question
Top Emerson Car Audio & Video Experts
xxxxxx xxx
Are you an Emerson Car Audio and Video Expert? Answer questions, earn points and help others
