Question about HP Photosmart R927 Digital Camera
Can't unlock my camera card on hp photosmart M425
My camera is showing crd locked.How do I unlock it?
  • 3 Answers
If we are talking about an sd card, on the opposite side to the 'cut' corner is a small piece that slides away from the contacts to lock, slide this away from where it says lock if this is the case, but make sure it wasn't protected to save something important before use, This may have caught on something as you slid the card in, and it's only tiny!
Posted on Mar 07, 2009
Can't unlock my camera card on hp photosmart M447
Posted on Oct 01, 2013
HP Photosmart M425, "Card Lock" message, camera
Take the memory card out of your camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Nov 05, 2010 | HP Photosmart M425 Digital Camera
Camera: HP Photosmart R725. Can't format SD card; says its locked when its not.
dear sir,
even after removing the lock(by pushing the push button at the upper side of the card which allows the card to lock and unlock)and when you are trying to format it,it shows formatting cannot be done right??????????////
all right,just take the card and put in a card reader and try formatting,hope this helps...even after trying in crd reader if ur card cannot be formatted,then the card is being corrupted..........its advisable to go for sandick or transcend memory cards which have a longer life and some important pictures or joyfull moments being picturised if missing,it hurtsa lot,because i also faced this problem........
thank you...take care
Oct 08, 2010 | HP Photosmart R725 Digital Camera
Camera card locked
Move the slide switch on the side of the card.
Jul 12, 2010 | HP Photosmart M425 Digital Camera
Photosmart M425 Digital Camera: How do I get my memory card unlocked?...
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 18, 2010 | HP Photosmart M425 Digital Camera
Keep coming up after each picture card is locked
Remove the SD card and flip the switch on the edge of the card to unlocked.
Jan 17, 2010 | HP Photosmart M425 Digital Camera
Reads Card locked when trying to delete pix from mmemory card
Dec 25, 2009 | HP Photosmart M425 Digital Camera
Can memory card be blocked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 29, 2009 | HP Photosmart M425 Digital Camera
Cannot take pics...says card locked....what does that mean??
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 18, 2009 | HP Photosmart M425 Digital Camera (5MP,...
Screen says "card is locked"
You have an sd card for this cam, depending on who made the card
there is a little white tab,or grey, on the side of the card, you can see that it can slide back and forth, and you should see the word lock,
just make sure the little tab is not on lock, slide it the other way.
You max card size is 2gig, and the first time you put in a new card you have to format the card with the camera.
Mar 16, 2009 | HP Photosmart M425 Digital Camera
Wrong format on HP M425
Just fixed this problem on a M525 camera (same physical construction).
Do a search with M525 and format.
Feb 10, 2008 | HP Photosmart M425 Digital Camera
HP Photosmart R927 Digital Camera Logo
239 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
