Question about Epson Stylus C66 Inkjet Printer
Epson c66 won't print
Have'nt used this printer for over a year. Cartridges show full but head and nozzle cleaning have not helped. Paper just continues to come thru blank. Anyone with any other ideas. Thanks DAK
  • 353 Answers
If your cartridges have been sitting in the printer for a year, it seems likely they have dried out. Replace them with new cartridges, but make sure you use the proper cartridge replacement procedure so that a ink charging cycle takes place. Then do a nozzle check. Is there any sign of ink on the paper?. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may
now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. Try this process twice if necessary. If still nothing, post a new comment detailing what you have done and the results.
Posted on Mar 09, 2009
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
Hello, our C66 printer won't print. It has been unused for about 2 years, we've put all new ink cartridges in, downloaded the latest drivers, and nothing gets printed. You can go through all the test...
The most likely cause is the print head nozzles are blocked with dried ink and inserting new ink cartridges won't fix this problem. You need a new print head.
Print heads are not cheap, you may be better putting your money towards a new printer.
Jan 06, 2011 | Epson Stylus C66 Inkjet Printer
The printer connects to the computer and pulls pages through fine, but the pages are coming out blank. I've replaced the ink and cleaned the nozzles but nothing will get it to print!
Hello.
I know you've cleaned the printheads, but try this method:
(1) Open the printer
(2) Remove the color ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then the print head(s) may need to be replaced.
Hope this helps.
Oct 23, 2010 | Epson Stylus C66 InkJet Photo Printer
My epson stylus cx3200 is not printing quality images
clean heads and nozzle (a few times) in maintaince. Check allighnment there too and chose correct paper setting for the paper you use
Feb 18, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Black Ink won't print
epson printers are very picky about the ink it could be possible that the off brand ink has ruined the print head
Feb 10, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
Nov 16, 2008 | Epson Stylus C66 Inkjet Printer
Epson Stylus C66 inkjet Printer does not print !
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Nov 12, 2008 | Epson Stylus C66 Inkjet Printer
Printing
Do some head cleanings using your driver utilities
Go to control panel>printers and faxes>right click on the stylus c66 and go to printing preferences>go to maintenance tab and do head cleaning for about three times and then try to print
Feb 14, 2008 | Epson Stylus C66 Inkjet Printer
Prints yellow vertical lines on all color print jobs
Try to do a nozzle check/ Turn printer off/ put in a plain paper
Press and hold the middle button on the printer while turning it on. When it turns on you can realease the buttons. Should [print the nozzles/ check if there would be gaps of missing colors/ if yes do head cleaning by going to printers and faxes under contorl panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Jan 21, 2008 | Epson Stylus C66 Inkjet Printer
Cartrige refilled reset but no colourprinting epson stylus c66
Clean the print head/Control panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Nov 02, 2007 | Epson Stylus C66 Inkjet Printer
Epson Stylus C66 Inkjet Printer Logo
213 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
