I have a seimens washer drier. The problem, shortly, is that it won't go onto or past the 'rinsing' cycle. The machine will fill with water and do the wash part of the cycle, but not go any further. It comes with an error code three, which (i think) means that something is blocked or won't drain away. I am sure the pump is working, as when I've done a wash I need to pump the water out of the machine, and it does this with no difficulty. I can move the program along the cycles, and will do the fianl spin no problem. I've checked the filters at the back of the machine and they are both clear. The cycles are 'washing' 'rinsing' 'final rinse' and 'spin'. I can select the various cycles, but it simply won't rinse. The instruction manual gives the model SIWAMAT 6102 or 6142
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Maytag_lse7804ace: washer won't fill with water. If I fill it by hand, the cycle works fine (until it gets to the rinse cycle, when it won't fill again).
Hello John,
The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red 11_4_2011_1_39_54_am.jpg
Nov 03, 2011 | Washing Machines
Going through full wash as normal but won,t go onto rinse or spin mode?
Most front load units must have two things, door must lock and must sense cold water for rinse. I would check the fill line for the cold water, if clogged with sand, it will not progress through cycle. If the unit doesn't drain it will not spin, is there water left inside the drum area?
I am here if you want more assistance
Aug 28, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
No water inputted in rinse cycle
Turn off the cold water valve supply to the washer and unscrew that hose off the back of the machine. Take the screen out from inside the washer where the hose was screwed onto. Clean out the screen and re-insert it. Re-attach hose, turn valve back on. Presto, better water fill rate.
Jul 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
No rinsing water coming in
There are 2 versions of this washer dryer, a cold fill only one and a hot and cold fill version.
If it is the cold fill version, it could be the water level switch that is malfunctioning, cutting off before the correct level is reached, or a sticking water inlet valve.
If it is the other version, then the same thing applys, plus the coil on the valve that controls the rinse cycle could be open circuit.
You need a meter to test the valve coils for continuity..
Make sure that there is actually cold water to the valve, if it is a hot and cold fill model.
Plz rate my solution.
Jan 11, 2009 | Indesit W 123 Front Load Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it to turn it off...and turn the timer slightly the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Washing Machines Logo
201 people viewed this question
Top Washing Machines Experts
