Question about Frigidaire FRT15B3A Top Freezer Refrigerator
Nasty smell in garage.....think its coming from refrigerator
In the back of refrigerator on the bottom left, there is a black box full of fluid and something very nasty looking and rotten smelling. Does this box come out? If so how. I can't find the manual to this refrigerator. We think this is where the funky smell is coming from in the garage.
    President:
  • 2,976 Answers
It's either the drip tray which is removeable from the front, or, mice are playing in the drip tray under the compressor. Soak in up, rinse with some ammonia water & repeat a few times. Rinse well when done. Line up some sticky traps behind the fridge. The mice found a playground amd they will return.
Posted on Mar 07, 2009
Help!! Bad Smell coming from AC/Heater will driving but when idle no smell from under the hood.
Sounds like the volatile fluid gas that is used in the refrigeration of the ac unit has leaked or it needs resealing and regassing.most garages with ac repairs techs will know this.Its about £75 in uk money to regas such a unit.did the air conditioning unit not work as well during preceding weeks is a sure telltale sign it needs regassing.good luck.
Jan 16, 2015 | Chevrolet Cars & Trucks
Tip
Bad odor in refrigerators...
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
  1. Keep an open box of baking soda inside the fridge it will absorb the foul smell.
  2. Place newspaper made into balls all over your fridge and freezer so that it is completely covered.Spray the newspaper with water until it is completely wet.
  3. Allow the fridge to run as normal for five days. During this time, the combination of evaporating water and paper will soak up the nasty smell. It should be noted that you will have to turn your freezer to the lowest setting to avoid getting frozen.
  4. Buy some freshly ground coffee.Dump 1 to 2 cups of the coffee grounds on a large plate and spread them around. Use multiple plates if the smells are extreme.Place the plate on the center shelf.Close the refrigerator for 24 to 48 hours.Dispose of the coffee grounds.
  5. Cut a lemon in half and put it in there - it will absorb the smells and make it clean smelling.
  6. Last but not least ....Empty contents of fridge wipe out with warm water and a little lemon juice then cover a tray or plate with kitchen foil and fill with charcoal put in fridge over night and the charcoal absorb es all nasty ouders then in morning remove plate or tray.It should have no smells at all.
Thank you for this opportunity t post few tips which i know. I think all the above are home made tips and anyone can try it out who are facing the problem of bad odor in their refrigerator..
on Oct 18, 2009 | Kenmore 50522 / 50524 Side by Side...
There is a bad smell that I get a wiff of when I walk by. The smell is on the right hand side of the frig. Sometimes it can be smelled for a short distance. The smell is not coming from inside the frig,...
Some of them do have a drip pan under them ,at the bottom of the frig there is a cover that will come off may be screwed on may snap off when you pull on it.Take a flashlight and shine under it after you get plate off you should see it .You can put a cap full of bleach in it should take care of your problem.
Sep 20, 2017 | Whirlpool GX5FHTXT Bottom Freezer French...
Ice maker stopped making ice and now is leaking from the back of the fridge.
Here is what I think it might be: The water valve has a slow faucet like drip that forms a stalagmite in the fill tube. When the ice maker calls for water the water goes out the backside. OR it might be the line has a hole in or has come off the fill tube in back of the ice box. Solution: replace water valve and blow dry fill spout to get out ice.
Apr 01, 2010 | Maytag 24.8 Cu. Ft. Side-by-Side...
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
My new cuisinart breadmaker has a strong nasty smell coming from the bottom. I have already returned one for the same reason so I don't want to send this one back. It makes my kitchen smell really nasty....
Hmmm... I'm back again. My machine still smells terrible! I live in a relatively small, open plan apartment and this bread machine is smelling up the place. I am very unhappy with this because I am otherwise pleased with the bread it makes.
I removed the bottom plate to see what is causing the smell. I have NO doubt whatsoever that the problem is the rubber belt, which I believe controls the kneading paddle. I've taken to leaving it outside to air but am stumped for a permanent resolution.
Any remedies for stinky rubber that I've come across involve liquids, heat or powders etc.. just things in general that wouldn't be prudent near the electrical panel, as well as not wanting to take the risk of damaging the machine and having it stop working altogether.
I got it at Costco in January, no hope of returning it there. Has anyone contacted Cuisinart about this? I wonder if they are aware of the issue if it seems to be widespread. I am in Ontario.
What happened with the B&D? Did the problem ever resolve? Irony is that I had returned a smelly B&D in order to get the Cuisniart! Same problem, but IMO I think it was worse with the B&D and the Cuisinart is a better machine over all (if it didn't smell so bad!)
Jun 22, 2008 | Cuisinart CBK-200 Bread Maker
Very bad odor in Maytag refrigerator
There is a very bad smell from the bottom of the refrigerator . There is a pan under the refrigerator with a very bad smelly Liquid , How can I clean that pan I couldn`t pull it out ? Thank you
Feb 20, 2008 | Refrigerators
A leak from the fridge
Without knowing a bit more about the black fluid it is hard to guess where it could come from - in a fridge there should be no black fluid and the only oils are mixed in with the refrigerant so the fridge will not be working if any noticeable amount is leaking out, as the gas will leak out as well. As you mentioned, the most likely liquid is water from inside the fridge or condensation from inside or outside that has bacteria growing causing the blackness. this sort of water may usually only be in the water tray at the back but there are many possibilities of it leaking out somewhere else - only way to check is to get the fridge running, up on four chairs or a VERY strong glass table so you can see where it is comning from. Another possibility is that there is some insect, plant or rodent factor - the moist warm space under a fridge is quite popular and they can produce their own liquids and also especially rodents cause unpredictable holes and damage all over the place. also can only be checked by looking very closely at the source of the liquid. The last possible cause i can think of is some sort of corrosion - i have not heard of this type of corrosion with a fridge, but it is quite common on steel ships - salty humidity and chemicals (cleaners/cargo etc) reacting strangely with the paint or steel are normally blamed - just think if you get too many strong cleaning products near the bottom of the fridge and look for general condition of the paint/metal underneath you should be able to see it easily if the black fluid was in any significant quantity - there would usually be a sort of rusty look to the fluid, but not always depending on the combination of chemicals present. Where you describe the fluid coming from, sounds like it could be from the door insulation - maybe leaking through the bottom hinge holes - check that nothing is leaking into the door from inside, although condensation can easily happen in the door body itself if the insulation has separated slightly from the "skin" of the door inside. Last thing to try is to investigate the fluid itself a bit more closely - get some on a piece of kitchen paper towel or a coffee filter and then wet the paper with water also just next to the fluid- the parts of the liquid should separate out a little as the water soaks through the paper and you may just see something that looks familiar. If you get no luck post back and try to describe exactly what the fluid does smell like, without trying to imagine smells like "oil" which means nothing as they are all different and in particular fridge lubricants are relatively odourless. think of things you actually know the smell of and try and describe it in those terms - if you feel brave then it may be worth tasting the liquid - just taste a tiny tiny bit on a cotton bud/Q-tip dabbed on a few different areas of your tongue and then wash your mouth out with mouthwash straight after instead of spitting or swallowing - I know it sounds dangerous and disgusting but it is the way that many professionals identify unknown substances as taste has a much more specific "database" in the brain than smell has. just be sensible. Hope this helps - post back if not - photographs may help if you have a digital camera, especially of the coffee filter test if you get round to it :) Good luck
Jun 22, 2007 | Kenmore 64802 Top Freezer Refrigerator
Frigidaire FRT15B3A Top Freezer Refrigerator Logo
337 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
