SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
SOURCE: cooktop burner doesn't switch between small and large
The burners are controlled by switches, that are the one you turn when you turn the knob. Iwf the burner does not switch to high mode than you need to change the switch.
The switch for your appliance has part number:
WB21X5243
You can by the part from manufacturer clicking here.
Here is an exploded view of your kitchen panel.
The switch is indicated with number 3 in the picture, There should be at least ttwo of them, depending on the model. That is what you need to replace.
Its price is $40.50 from GE.
If our posts had been helpful do not forget to accept the solution.
Regards
SOURCE: INTERMITTENT BURNER ELEMENT
Take out the element and look at the connecting ends see if there are char or burn marks where they make the connection. One thing you might try doing is cleaning the connections, if that does'nt work you will probably need to replace the element.
Hope this helps ya
SOURCE: Burner Heating element doesn't heat
Check power to element with a voltmeter. If there is power, the element is bad. If not power, than switch or relay is likely faulty. You can also test them with an ohmmeter
