Question about Intel PIII 550Mhz 512K Cache CPU SLOT 1 w/Fan (550piiifanoem)
My dasktop doesn't completely load windows xp setup
My desktop (PIII processor) restarts automatically during shut down. tried to run set up (WIN xp) but after 39% completion of the loading processing it reboots automatically and doesnot go beyond 39%. Hard disk is ok. tested in other machine. pl.advise regarding problematic hardware/software etc
  • 167 Answers
Hi, did you run the upgrade adviser, before running xp set up? this will tell you any upgrades or possible problems you may have. it is probably a hardware compatibility, as the aging p3 systems would have. if you can, go back with the older operating system, then run upgrade adviser, you may be able to correct he issue, i still have a pentium 2 450,that i put xp on years ago-it runs great for a p2-so it is not impossible to do.also did you do a quick or full format in the fat or ntfs, do full, and try the fat format for that p3. hope this helps you, good luck! need more help post again.
Posted on Mar 08, 2009
Why does desktop pc running win xp pro, when choosing "start/shutdown/restart", fail to restart, but if choosing "start/shut down/shut down" it works fine?
http://superuser.com/questions/14163/when-windows-xp-wont-restart-how-to-diagnose-how-to-shutdown-without-power-c
May 23, 2014 | Computers & Internet
Freezes at Dell splash screen
you will need much more ram mem for win7 than win xp, perhaps upgrade your ram mem, and see if that solves the freezing issue
Feb 28, 2013 | Computers & Internet
Windows xp start up disk doesn't work
if you are referring to the installaion disk
restart your computer during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
Apr 16, 2012 | Computers & Internet
'setup having problems to shut down auto run program' Sims 1!
Try to clean your CD's thoroughly before installing it and "run it in administrator account"........
Feb 10, 2012 | EA - Electronic Arts Sims: Complete...
My computer does not find multimedia controller and can not install automatically.what is wrong?
Restart your pc and pres F2/F10/Dell,for set up bios ,
set up your bios as load fale save default , and pres F10.
After complete bios setup install the audio and graphics driver .
Good by,
Jan 31, 2011 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
I can't shut down my PC,It restarts again!
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Start up and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts. For additional information, click the following article number to view the article in the Microsoft Knowledge Base: 308427 (http://support.microsoft.com/kb/308427/ ) HOW TO: View and manage event logs in Event Viewer in Windows XP To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
Note: You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
  1. Log on to the host computer as either an administrator or the owner.
  2. Click Start, and then click Control Panel.
  3. Under Pick a category, click Performance and Maintenance.
  4. Under the or pick a Control Panel icon section, click System.
  5. Click the Advanced tab, and then click Settings under Startup and Recovery.
  6. Click to select any one of the following check boxes under System Failure:
    • Write an event to the system log
    • Send an administrative alert
    • Automatically restart
    At last if nothing works then clear the "Star up"
  7. C:\Documents and Settings\All Users\Start Menu\Programs\Start up
    If you are not satisfied then If you are using XP then repair it.
thanks
Jul 05, 2010 | Computers & Internet
Dell Inspiron 530s/531s desktop, Win. Xp home...Windows stops responding at the ''Loading Personal Settings'' cannot boot in safe mode.
try to boot in "Last good known configuration settings" by restarting your pc and then press F8 before windows appear and then select the boot option i mention above. if this not work since you said that it can't boot to safe mode, your other option is to repair the windows or else reformat it. when you repair the windows you must have windows xp home edition cd installer, you load it to your cd/dvd rom and then restart your pc and press F2 or DEL button before windows appear in order to go to setup bios settings. in bios settings, you choose boot order setup and setup first priority to cd/dvd and press F10 by saving the changes and then press any key when you see the prompt so that it can boot up to windows xp home cd installer and then follow screen instruction that you arrive to windows repair option.
Mar 27, 2010 | Dell Inspiron 530 Desktop Computer
Hai friends........ I am not able to shut down my PC
Ive seen this happen B4..
try holding the power button in..
If your useing the power button every time, it could be sticking,, Or you have it setup to restat when the power button is pushed.
If button is ok and power setting are set right then its *********** board
Dec 01, 2009 | Microsoft Windows XP Professional With...
My desktop computer restarts automatically after every 5 min or so. OS is Windows XP., PIII Processor.
If its a blue screen that appears or it does it automatic then you have either a virus or a registry error. take it to your nearest computer repair man.
Sep 17, 2009 | Computers & Internet
I can't play mission runway it won't load? i tried to do it on run but it wouldn't work what do i do next? is there a phone # i can reach you at?
Did you make sure that your computer is capable to run that game?
System Requirements:
Win XP/Vista
Processor: PIII 1.4 GHz
DirectX 9.0
512 MB RAM
Free hard drive space: 1.2 GB
Direct 3D 64MB DirectX 9.0
DirectX-compliant Sound Card
May 24, 2008 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
