Question about Panasonic PT-44LCX65 Television
Pt44lcx65 At first green dots on the screen now no picture. I have been told that the color wheel needs to be replaced. Can't find that part anywhere. Is the color wheel part of the lamp fixture and if so can I just replace that?
  • fryzo2 Mar 07, 2009
    we'll se how far i get in the replacement process before i ask another question
  • 10,594 Answers
Your TV does not have any color wheel inside. Most probably it can be problem of Lamp and you can buy new lamp from Part Store.
Posted on Mar 07, 2009
  • Panasonic Master
  • 19,396 Answers
You can buy a replacement at Partstore.com.
  • Ginko
    Ginko Mar 07, 2009
    Yoou can find all replacements for your TV here: PT44LCX65.
    The color wheel iwill not be listed because it is sold in base of chassis, not of the model.
    To buy the color wheel give them a call at 1-866-925-PART (7278)7 days a week.
    Sergeant:
    Novelist:
  • 277 Answers
Howto replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
you will also get the parts here.
There is a humming in back of tv.the sound always good but picture doesnt come thru and i get a green screen someetimes blurry with distortion.color wheel or dmd chip or lamp starting to go out
as my experience, the most possible reason should be the color wheel or its photo sensor board.
firstly try to clean its photo sensor board, or have to replace a new wheel.
i just have this wheel, when you need to replace it, contact me freely
May 02, 2016 | Televison & Video
I have a panasonic pt-60dl54, the sound works but green picture
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.You will need to replace the DMD board. Have a blessed one!
Apr 13, 2010 | Panasonic PT-50DL54 50" Rear Projection...
I was just given a sony kp51ws500 tv however they told me the color wheel is broken and the picture is green im looking for the part number for the new color wheel and how hard it is to replace
KP-51WS500 IS a rear projection set and does not have a color wheel
I suspect you may need to adjust the green screen control---if you do not know how to attempt this let me know and I will post the instructions here for you.
I am here to help people
SD TECH
Sep 30, 2009 | Televison & Video
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
RCA DLP TV with a red dot in the middle of the screen
Sounds like the color wheel stopped and re-started. It may continue to function for a while, but could fail at any time.
I've also seen on rare occasion, a defect in a lamp produce uneven color rendition, but its far more likely that the culprit is the color wheel.
michtech
Feb 13, 2009 | RCA D52W19 52" Rear Projection Television
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color wheel problem on my HLP4663WX/XAA
The color wheel is not working, and failed in green. The best case is a cable is loose, color wheels typically have a two pin power connector and a ribbon cable for phase locking. If it is not these connections, you will not be able to fix it yourself.
Sep 21, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Panasonic PT-44LCX65 Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
