Question about Pioneer PDP-425CMX 42 in. Plasma Television
Dpo adjustment lost my maual how do you adjust color etc
    Scholar:
  • 53 Answers
Press the menu key on the remote on on the tv itself. Look for the menu option that says "setup" or Video Adjust, or something of the like.  It should give you options like: color, tint, sharpness, etc.
Just browse through the menu to see how yours is setup.
Hope this helps.
enov8
Posted on Mar 07, 2009
Got a used sony 3v36fs16 36". color convergence needs adjustment. can i do this myself?
yes you may need the maual unless the remote has an auto convergence, if you have no manual but can access the convergence menu your goal is to line all the colors up with the diagram
May 16, 2010 | Sony KV-36FS16 36" TV
Color loss
Hi, right click on an empty area of th e desktop, select "Properties," next, pick all areas that will apply: Windows Color and Appearance, Display Settings... make the adjustments, "resolution etc. "Rating the solution is appreciated, thanks."
Apr 13, 2010 | Acer AL1916W 19" LCD Monitor
TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
Jan 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Can't adjust color, brightness, etc. w/universal remote
Use the MENU on the front panel display of the
TV
Jan 06, 2010 | Televison & Video
Akai PT5499hd that has suddenly lost color alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 23, 2009 | Akai PTH5498 54" Rear Projection...
Adjusting color/ user mode??
The TV will not let you set brightness, contrast, color or tint in the preset modes like Vivid, Movie, Standard etc. Look for a mode that says custom, user etc..
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
Cartridge Finishes early
Unfortunately that is a technical issue.
1-adjustment of the Seperation
2-adjustment of the developper
3-adjustment of the Primary bias
4- etc.. etc...
You need a tech to go in and see which adjustment needs to be reset or calibrated. Most adjustments are done in the service mode but you still need to know how anad which one. The SERVICE manual is the only thing that will tell you and how to adjust.
Aug 14, 2008 | Canon Office Equipment & Supplies
Night time scenes have become almost impossible to see.
I had the same problem. Figured the 8 yr. old set was on it's last legs. Read everything I could find and nothing helped. But, luckly I did the following and it's like new again! try the following: Press MENU, selectSETUP, select DPO, set it OFF. DPO automatically controls Contrast, BLACK LEVEL (Brightness) and Color. Now press Menu, select PICTURE, then select BLACK LEVEL and run it out to plus 25. your picture should be brighter. Then adust Contrast,Color and Black level to your liking.
Jul 13, 2008 | Pioneer SD-532HD5 53" Rear Projection...
KV-36XBR450 CANNOT ADJUST COLOR
This sounds like you might of lost one of the colors of the crt. I would suggest that you take to a repair shop.
Jun 27, 2008 | Sony KV-36XBR450 36" TV
Bad color on sony kv-36fs16
Possible bad CRT....check video out on C board,video drivers on
A board.........................T.
Dec 23, 2007 | Sony KV-36FS16 36" TV
Pioneer PDP-425CMX 42 in. Plasma Television Logo
128 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
