Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenwood elite glass top range shows error code F7 for all burners.
  • 1,959 Answers
F7 indicates a stuck touch pad key. Try pressing all teh buttons on the key pad to see if one is stuck. If you don't have a stuck key, there may be a problem with the key pad module itself
Posted on Apr 19, 2009
Alarm comes on and display shows f7 code
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Kenmore 47702 / 47704 / 47709 Electric...
My oven beeps and show error code F7 on the panel. Help!!!
Kevin
Dec 02, 2010 | GE 27" Built-In Double Electric Convection...
I need to know whay is an error F7 on my kenmore oven. Every time I plug the oven on I get an error F7
The F7 error code indicates that one or more potentiometers (burner switches) are not connected properly or that you have one or more failed potentiometers.
The specific details of this failure code are provided in the second image below.
This is an excerpt from the technical information for this range.
Normally, a service technician would be needed to conduct the troubleshooting and diagnosis for this type of failure.
If you are completely confident in your technical ability to safely unplug the range and access these potentiometers (54 in the third image example) you may be able to check for loose or broken wires that could be causing this code.
If no loose wires are found, then you will likely need to have a technician find and replace a failed potentiometer.
IMAGE1: http://media.fotki.com/1_p,wfdddkwdfrwkdtqxgtqsskgwtqkq,vi/gfwdtqtbrxgdkgqwqtb/1/1303472/5961857/image11662img-or.gif
IMAGE2: http://media.fotki.com/1_p,wfdddbrbbbbgfttxgtqsskgwtqkq,vi/gsfkbbsqqxgdtwdgbsg/1/1303472/5961857/image11663img-or.gif
IMAGE3: http://media.fotki.com/1_p,wfddfqsqwsbqtrwxgtqsskgwtqkq,vi/gtfggdrdwxgftrgbbtf/1/1303472/5961857/image11664img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 01, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a kenmore elite electric range and it is diplaying a F7 code what can I do to fix it.
f7 error code usually means stuck function switch on control panel. Need to check each button or switch to see which one is stuck
Mar 19, 2010 | Kenmore Ovens
I have the Kenmore model 91147642100 double oven. F7 is showing and oven will not work on top or bottom
Feb 24, 2010 | Kenmore 47732 / 47734 / 47739 Electric...
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jun 20, 2009 | GE JKS05 Electric Single Oven
Range led flash code F7
Here is the error information for Fault Code F7
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Hope this is helpful, I will also provide you a link to to a helpful site.
http://www.applianceaid.com/fault_codes.html
Mar 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
Error code f7 on Kenmore wall oven 911.41165791
Feb 03, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
F7 code on kenmore oven and beeps what do i do to turn it off
Nov 11, 2008 | Kenmore 42161 / 42169 Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
276 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
