Question about Motorola Mobility KRZR K1m Cellular Phone
Krzr won't stay on t9 text
When I create a text message and set it to t9 text it won't stay on t9 setting.
  • George Bill
    George Bill May 11, 2010
    Is that the font, that you are altering? and if so, has it worked before where it kept the style that you selected?
Open a new text message go to "options" select "Text Setup" and change the primary text: to iTap English instead of TAP English this will fix ir :]
Posted on Apr 01, 2009
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
Moto Krzr keeps sending text messages as Pix
Depends on your service provider. I believe there is a default setting or tap the softkey to change. You may want to check on forums.motorola.com. i would also check www.motorola.com/support
Nov 26, 2009 | Motorola Mobility KRZR K1 Cellular Phone
How to take t9 off boost mobile i570?
There is no option on the i570 to actually " Turn off " T9, but there is the option to switch from "Word" to "Alpha" with eliminates the annoying T9 from interrupting your text message. The way you do this is by creating a new SMS text message or "Reply" to an existing message in you inbox. Either way works. Once in the new message window you want to press the "menu" key you will see "Entry Method", you then just want to select "Alpha" instead of "word" and the T9 will no longer be active.
Nov 16, 2009 | Cell Phones
I580 Predictive Text!!!!????
Go to Messages,then go to Create SMS the message multiline appears . Now press the round button in the centre of directional keys, this will take you to message editor. Now go to Entry set up . In the Primary setup select TAP english and in the secondary set up select TAP English.
Oct 13, 2009 | Cell Phones
SMS
to turn off predictive text go into messages-select- create new -select-message-text message-select then press and hold the * key and you will see in the top right corner it changes from ABC to abc or T9. to send sms messages go to settings -select -application settings-select-message-text message-select-sending options-select- GSM alphabet then maximum then text.
Hope this helps.
Sep 09, 2009 | Samsung J700 Cellular Phone
Change text message language in Samsung SGH-U900
Try holding down the # key and a menu should pop up with the various typing styles. I changed mine to T9 abc and it works fine now
Nov 14, 2008 | Samsung U900 Soul Cellular Phone
Predictive Text
To get predictive text on or off on the LG Shine go to:
>Menu
>Messaging
>New Message
>Text
>Options
>T9 languages
>T9 on/off
Sep 01, 2008 | LG Shine KE970 Cellular Phone
Changing language so i can text message
open a creat new tex message options and look for somethin like edit T9 dictionary, input language input type failing this come out of the thx message to messages and find settings and repeat above
Jun 17, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Can't receive text messages
Check in:
Menu,
Messages,
select -Options-
Settings,
Text Message,
Reply Via Same Centre (choose NO)
this might do the trick.
Dec 01, 2007 | Nokia 7373 Cellular Phone
Predictive text on a motorola w375
Go to Messages -->Create-->SMS/EMS-->the message multiline appears . Now press the round button in the centre of directional keys, this will take you to message editor. Now go to Entry set up . In the Primary setup select TAP english and in the secondary set up select TAP English.
Oct 24, 2007 | Motorola Mobility W375 Cellular Phone
Motorola Mobility KRZR K1m Cellular Phone Logo
777 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
