Question about Exercise & Fitness
I need directions on how to replace the end cap on my proform 745cs treadmill.
  • Anonymous Mar 15, 2014
    proform 745cs incline
    Problem Solver:
  • 13 Answers
Go to:
http://www.iconservice.com/manuals.html
fill out form......search.... view manual in PDF Format
Print
It should be in the exploded drawings near the end of the manual
Posted on May 13, 2009
After recalibration, incline still doesn't work
Some elevation motor has 3 things:
1) Capacitor test it.
2) Limit switch for up and down,
3) Relais for up and down.
You must test it before to replace the complete elevation motor.
4) See if there are 110Vac to the terminal of the motor, if there are the motor is Faulty, If not test the 3 steps mentioned before.
You can go to Treadmill Doctor
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 08, 2017 | Proform 740cs/745cs Treadmill Walking Belt...
My proform 740cs has a squeak in the front left when i step onto the treadmill, even if off. I have tightened all screws, nuts, etc.
Dear sIR:
yOU HAve LUBE the treadmill, had been producing enough friction for to shut down and protecting the electrnoic system.
2) Lube the rollers bearing very well.
3) Test the voltage motor, if there are the motor need repair or replace.
4) Tes the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
May 13, 2012 | Proform 740cs/745cs Treadmill Walking Belt...
Ifit treadmill stuck on highest incline
RUN inmedaitely the software calibration for diagnose, troubleshooting and fix it. Now that machine is running in slow speed.
sincerly. God bless you
Apr 23, 2012 | Proform 740cs/745cs Treadmill Walking Belt...
Proform 745cs Service manual
Dear Sir:
As you must understand, the service manual, is only provide for tech service.
If would like to try in the website for proforma: go www.proform.com
after you go customer service and then parts& manual and then give you model, serial number, and download for free ONLY User manual. You must contact for Contact Us, and explain you situacion and they will contact you, and most probably they charge some FEE, for the Service Manual.
sincerely.
E.CUADRA
MANAGUA NICARAGUA. C.A.
Nov 27, 2011 | Exercise & Fitness
Hello! We have a ProForm 550 treadmill. No matter how many times we straighten and tighten the belt, it immediately moves to the side rendering the treadmill unusable. Any thoughts regarding what is...
several things could be happening, 1) the rear end caps that hold the roller can be broken not keeping in adjustment the roller. 2) the walking belt bad. 3) roller back or front worn(less likely). also make sure if your belt(the new one if you need it) uses lubrication or not.
good luck to you.
Feb 08, 2011 | Proform Exercise & Fitness
Turns needed to install adjustment bolts on rear roller of treadm
There is no turn amount, you just want to go until they are snug. Do not crank on the bolts or force them you will be able to tell when tight enough
May 31, 2010 | Proform LX660 Treadmill Walking Belt
Can I glue the torn edge of my treadmill belt?
I would question why it traveled to the right and cause you grief. Before anything else run the unit and see if its going travel to the right again if it does then check right end cap for breakage. To your first question no you cannot glue the belt they use a high temperature gluing process for the seams you'll have unfortunately replace the belt.
May 20, 2010 | Proform Exercise & Fitness
I need the key for the 740 cs model
Call Icon fitness @ 1-800-999-3756
Part #: 119038
Part Name: ASSY,CLIP/ROPE/KEY
Model: 299460 - PROFORM 740CS/745CS
Part List: #119038 - KEY/CLIP
Quantity on Model: 1
Price: $2.35
Weight: 0.020lbs.
May 14, 2010 | Exercise & Fitness
My proform 745cs keeps sparking and blowing my circuit breaker.
It sounds as though you have a short within your machine. Either a faulty control board, or a wiring fault. You need to get an electrician/service person to check it over and correct the fault
Apr 18, 2010 | Exercise & Fitness
I have a ProForm 625 and the belt has started to slide to one side. How can I fix it?
Check the rear end cap. (end where the adjusting screws for the belt are) check for cracking around the screws they have more than likely broken through the end cap and are no longer adjustable.
Nov 10, 2009 | Proform Weight Loss 620 Treadmill - 24755
Exercise & Fitness Logo
197 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
