Question about Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket AM2+ 3000 MHz Motherboard Retail
Motherboard GA-MA790FX-DQ6 no monitor
Please help.
I have purchased the above motherboard and have encountered a few issues.
I currently have the Phenom 9500 quad core processor, the Zotac 9800GT Graphics card, 1TB of harddrive and 8gb RAM 4x2gb.
The only generic output on the motherboard is the serial output (motherboard has the female output), when I turn on the PC there is no input to the monitor (which works with 2 other PC's I have connecting in the same way) there is no beep from the speakers to state that there is a problem and there has never been any sound at all.
I have tried another CMOS battery which didn't help, the rear USB slots do not work or give power to mouse or keyboard although the green and purple inputs will. I have tried a working and compatible AMD dual core processor as I have read that the motherboard only comes with F1 Bios and F5 is necassary without luck, I have tried connecting via the graphics card via HDMI without luck, I have tried without the graphics card using the standard nvidia on motherboard. There is power as all my fans work fine, the blu ray dvd drive turns on etc
Please help
    Genius:
  • 1,066 Answers
Your power supply is too weak to power your video card.
Posted on Mar 11, 2009
Do I plug in BOTH the 20+4 ATX power connector AND the 8 pin 12V connector on a gigbyte MB (MA790GPT-UD3h)?
Hi
You only need to plug the 20+4 ATX power connector and how about the 8 pin 12V connector? Well that is use only for legacy type of motherboard that use to require it.
Hope it helps..
Thanks for reaching Fixya
Apr 03, 2010 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Long beep with pause continuous when booting up computer
Remove the RAM and reinsert and then reboot. Also same for the keyboard.
Oct 10, 2009 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Can not copy a part of XP OS file
Hi there.
Go here to Gigabyte support and download the BIOS update you need>>>>>
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_List.aspx?Keyword=GA-P35-DQ6
Good luck and thanks for using FixYa!!
May 26, 2009 | Gigabyte GA-P35-DQ6 Motherboard
Motherboard not booting
i think memory probelm
please change memory and try it
Jul 22, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Windows Vista
If you are having trouble installing the drivers from the Gigabyte CD, than go to Gigabyte's web site for the GA-M61SME-S2 motherboard & download the Vista driver's you need. The web site has some newer drivers. Click on this link to go to the driver site.
http://tw.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2507
If you are still having trouble. List what is not installing here.
Same for error messages.
Mike
Jun 26, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Motherboard is not booting!!!!!
Hi Jay,
Is you're memory installed in the two yellow slots?
Try using only 1 DIMM in DDRII_1 slot.
Page 17 in you're manual. When using only one PCI-E graphics cards you do not need to plug in extra power to the board, as shown on page 19. (Only need this additional 4-pin Molex when running two PCI-E cards).
Check internal connector is plugged in item,
1 ATX_12V_2X (Pg. 23 in you're manual).
(System will not boot without this).
Also item, 2 main power 24-pin Molex cable is securely connected. Chassis Intrusion Header (By default is opened/no jumper). I don't like the CPU getting hot. It shouldn't. Do you have a spare heat sink & fan for you're CPU? Are you 100% the cooling system is running correctly?
Lastly, here is Gigabyte's Qualified Vendors List (QVL), for you're board. Corsair 2GB is not listed.
http://www.gigabyte.com.tw/FileList/MemorySupport/motherboard_memory_ga-ma790fx-dq6.pdf
Luck!
Mike
Case fan runs on standby
Hi neezels, go to page 53 in you're manual. Scroll to the bottom of the page to ( System Smart FAN Control). This is you're case fan. This is why you're system fan is running while in standby.
By enabled you're case fan will still run but adjust it's speed acording to the motherboard temp. Even though you're system may be in standby you're case fan will continue to fun to maintain temp. (Pretty smart noard)!
Mike
Apr 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Troubleshooting
How long have you had the system in that configuration? It doesn't seem to be a heat issue running around 45 degrees unless that is the idle temp. I need you to try something, when it shuts down, immediately restart the system in bios and look at the temp for the processor again. I solved my issue by taking a side off of my case and putting a small desk fan blowing directly into it. My idle temp went from 45 down to 27 degrees celcius. In a perfect world, the cooler a CPU runs, the better the system will respond. Find those temps readings for me, and let me know. Also, there may be a small monotoring program in your mobo set up disc to help monitor the temp while windows is running. And also, double check to make sure your processor fan is plugged into the correct spot on the mobo, mine is mislabeled, another issue I had found and corrected.
Mar 17, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Trobleshooting
I had the same issue with my AMD Athlon 3800+ dual core. I found that I wasn't getting enough airflow to keep the system and processor cool. You may want to check the heatsink and fan rating for your processor unless it was sold in a bundle. Also, On AMD's of such power, they tend to run hot if overclocked. Look into, if you haven't already 2 case fans to go along with the processor fans. I recommend a 90mm in front and a 80mm in the rear of the case. If this doesn't help, let me know.
Mar 16, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket AM2+ 3000 MHz Motherboard Retail Logo
148 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
