Question about AMD Athlon 64 X2 4200+ Dual Core Processor - Socket 939 (AMDX24200)
My amd athlon 4200+ is heating to much like 70 degrees ...... when i play video games ....
  • 679 Answers
That's not unusual, it's about ten to 15 degrees over where you would like it to be, but right at the borderline of overheating. You need to add more cooling, either add a couple of fans, or get a better cpu cooler. Com/tiger, or newegg, has everything you need. The cheapses way is just to add a couple of larcer displacement fans to blow more air into the case, in the fron of the case, and add another in the rear of the case to pull out the hot air, get a flow going. If you can do a case mod, you can put one on top, and another on the side, which is what I have, it can be done for around 20-40 dollars, depending what you purchase. You should have used some arctic silver between the heatsink and fan, to get better heat dissapation.
Posted on Mar 07, 2009
Amd athlone 64x2 4200
Have you check to see if the 4200 is compatible with your motherboard? What are you installing the CPU in? The Make, Model of Computer? The Motherboard? Will you need more power? Another fan?
May 03, 2013 | Dell Computers & Internet
I had installed the game called WILL ROCK and while starting the game gsvideo Init failed is showing and the game is not playing.
Make sure you all have this system requirements.
MINIMUM PC REQUIREMENTS
Windows 98/ME/2000/XP
MINIMUM
Pentium III 500MHz or AMD Athlon 550MHz Processor
128MB RAM
32MB DirectX compatible 3D Accelerated Video Card
DirectX compatible Sound Card
DirectX 9.0
4X CD-ROM Drive
700MB Hard Disk Space
RECOMMENDED
Pentium III or AMD Athlon 800MHz Processor
256MB RAM (Windows XP)
64MB DirectX compatible GeForce3 or ATI Radeon Video Card
Mar 19, 2011 | Computers & Internet
When I play a game on my computer about 15 -30 minutes later it shuts down. Originally it had a 430 Watt power supply. I have now replaced it with a 650 Watt power supply. The hardware currently has a AMD...
Ok it was not your power pack but your setup in my opinion needed some extra Watts.
This problem is to do with heat, your PC is getting to hot and is shutting down to prevent it from being permanently damaged.
Click here for Hardware monitor, on the right hand side of the screen, click 1.16 setup, english
Click here for GPU-Z, click TechPowerUp GPU-Z v0.4.7
This will download both Temperature monitors.
Temperature's on the CPU should NOT exceed 30-40 degrees.
Temperature's on the Graphic Card should not exceed 65-70 degrees.
To solve this problem you must clean your whole computer case and components of dust. Particular attention must be given to the Processor and Graphics Card. Use a paint brush and a vacuum cleaner. Dust cooler off outside if neccessary.
Cooler Temps mean better Performance and a longer life span.
Ensure that the thermal interface paste is sufficient.
Install as many Fans as possible.
Please take the time to rate this solution it is the thumbs up on the top right hand side of this solution.
Thanks
Oct 27, 2010 | AMD Athlon 64 X2 6000+, 3.0 GHz...
I am using amd sempron LE-1100 i want to upgrade to a gaming pc so that i can play the sims3. so if i like to upgrade to amd athlon x2 how to know my socket type. please help
Your socket is AM2. You can put any AMD processor that has AM2. If the processor is AM3 just upgrade the bios of your motherboard and it should work. If you need further assistance, just leave a comment. Cheers
May 24, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Asus Monitor cuts in and out
for online games two things must be ensured 1. Internet connection having good speed 2. AGP card having at least 1GB memory and Ram 2GB. As per information given, you have check above
Oct 21, 2017 | ASUS VW193D Monitor
Can the amd athlon 4200 x2 proceesor be overclocked ? on the geforce6100pm-m2 motherboard
not a good idea over clock it to much without the right cpu heat sink and faster fan will make it over heat and possably blow up it should work with 2.4 if not u need at least a 450 watt power supply with that card
Oct 26, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
AMD Athlon 64 X2 4200+ Dual Core Processor - Socket 939 (AMDX24200) Logo
48 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
