Question about Akai LCT4216 42 in. LCD Television
I cant figure out how to plug in the direct tv cable
  • 4 Answers
Ther is no "cable" connector on this model tv. Check your direct tv control module "cable box" for a hdmi output. If you have that output, you will need ahdmi cable for HD broadcast. If you donot have a hdmi output on your direct tv box, contact direct tv for the right one. Do not use RCA connectors because the picture will be fuzzy do to in-ability for rca connectoe to send HD signal. You MUST have hdmi signal from cablle box to tv.
Good luck.
Posted on Apr 05, 2009
When i plug in hdmi cable to the wd52525 there is no hdmi imput on the device page. can't get it to work
If it is not there or grayed out you may have to try the soft reset first--set also has a hard one but only to be used as last resort.
Soft one: set on, menu,1,2,3 enter.
Jun 08, 2012 | Mitsubishi WD-52525 52" Rear Projection...
I cant her anything on wii
Can you see the video? If you are able to see the video on your Wii, check your connections going into the TV or Home Theater System. If it's not going directly into the back of the TV, I would suggest unplugging it from whatever else it is going into, then plugging it into the TV to see if you are able to get sound that way.
If you are getting sound when it's plugged directly into the TV, then something is wrong with your external source, but I would need more information to help you with that.
Component Cables should be plugged in as Green / Blue / Red / White / Red, standard A/V Cables should be plugged in to Yellow / White / Red.
Sep 28, 2011 | Nintendo Wii Console
Trying to hook up the dvd player to the home tv. Can't figure out which cables go where to get it to work. We have direct Tv.
Use yellow/white/red Composite cable to connect Player directly to an available A/V input on the back (or front or side) of the TV, just match the colors of the cable to the color of the plugs. You will now need to use the TVs remote to set the TV on the appropriate "Input". This button may also be labeled "Source" or "A/V". Make sure the player is on at this point. That's it!
Hope I helped!
Jan 12, 2011 | Televison & Video
How do i hook up my hd tv to record hd channels to my vcr
this is a hard question to answer because you cant just record from a tv to a vcr if your recording from an antenna you would have to plug it directly into the vcr and the vcr wouldn't be able to use the digital antenna anyway, if your recording from a satallite or cable u would have to go directly to the vcr then to the tv and the vcr cant record in hd
Nov 28, 2010 | Sanyo DP50747 50 in. Plasma TV
I turn on the cable box and the tv and about 1 minute to 4 minutes later the tv short circuits and turns off. The cable box is still on. The cable company came to change the box and the cables but it...
Sounds like there is too much voltage going into the same outlet. Please keep in mind cable boxes as well as your tv hold a higher amount of voltage then your dvd player. If your tv is plugged into the back of your cable box, unplug that and just plug it directly into the wall. If not, get a power strip and plug it in that way.
Nov 20, 2010 | Televison & Video
I hooked it up the way the manual said and it doesnt work
Try whatever applies best below, in order...
Cable Box optical Digital Audio to Digital Audio In. (This brings TV-related multi-channel and normal audio into the receiver so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the system on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box HDMI, Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
May 01, 2010 | RCA RT2380 Home Theatre System System
I cant get sound out of the Bose V30 and i lost the cable picture on Tv. What do i do?
I lost the video (HDMI) but can get all my sounds (TV, DVD, Radio, etc). HDMI cable is fine because it worke when plugged from cable box directly to the TV. Any suggestions?
Dec 22, 2009 | Bose Lifestyle V30 Home Theater System -...
Cant get a picture
1st-how do you have your "cox" cable box [you could have said it was a cox cable box!!] connected.Can you 'get a picture' through the TV without the VCR ? Do that! disconnect the VCR from the line and plug the TV directly to the "cox" box.Does it work? Are any of the cables connected from cox to VCR to TV damaged.? Let me know how you have the three(3) equipments connected.
Aug 07, 2008 | Toshiba W522 VHS VCR
How do I hook up to my Sony DAV X1V home theater?
Is there a headphone jack? The plug is just meant to plug directly into a headphone jack...let me know if it works!
May 27, 2008 | RCA WSP155 Main / Stereo Speaker
Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
Dec 26, 2007 | Universal Remote Control NspireGear MP3...
Akai LCT4216 42 in. LCD Television Logo
148 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
