Question about Audiovox fpe 3207 32 in. LCD Television
My Audiovox LCD TV is making a buzzing noise on and off.
It is not effected by the mute button.
  • 2 more comments
  • airsells Mar 07, 2009
    This is no help. All that did was take the static sound out of the buzzing.
    I'm starting from the beginning. It seems that my question was not posted correctly. My Audiovox LCD tv is making buzzing noises on and off when the tv is on. You can not make it stop even when you mute the tv. What is the problem?
    How do you repair the power supply problem?
    yes buzzing is still there even when you mute the tv
  • Audiovox Master
  • 19,396 Answers
Ensure that you are using a well shielded cable to connect the tv, try a replacement cable, often that can solve the problem.
Posted on Mar 09, 2009
    Sergeant:
    Novelist:
  • 277 Answers
In the tv on the main board there is a connecting capacitor whic control the sound on the board.that capacitor  is near to end of its life.its going to short out in the coming days/the number of the capacitor  is  C656rc that needs to be replaced. to make it completely clear.
Posted on Mar 07, 2009
  • 10,594 Answers
Can you provide more details on buzzing sound in your TV?
When you press mute button, buzzing sound still there?
If yes then it seems power supply issue with audio amp section.
Awaiting your comments to proceed further.
Thanks.
  • Shahid Electronics
    Shahid Electronics Mar 07, 2009
    ok, buzzing is there if mute is pressed. let me know do you get program sound along with buzzing sound or its just buzzing?
  • 2,323 Answers
The buzzing or humming noise you hear through the speakers is cause by the power supply. The voltage that is running the audio circuitry is low or not filter properly due to failing capacitors.
I repair these power supplies, let me know if you need further assistance or if you decide to the power supply repair.
  • Jaime Hernandez Mar 08, 2009
    The power supply is inside and to get access to it, the back cover and the pedesta stand will have to be removed. Once you locate the power supply look for leaky or bulging capacitors.
    Top class also mentioned a capacitor in the main board that could be defective as well.
    Brigadier General:
  • 8,619 Answers
Hi!
There is some problem with your remote and not with your tv. If you want the mute button to work then clean the remote internally, or if you are using a universal remote then re-program it.
  • Rylee Smith
    Rylee Smith Mar 07, 2009
    That sounds to be bad power supply circuit on youir LCD, get it checked.
    Check if you are using a (3 prong) grounded power socket.
    Please ask for clarifications.
    Thanks
    Rylee
    Sergeant:
  • 320 Answers
Check out the speaker mode is it on make it off from menu settings.
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Lg lcd tv buzzing sound
You have problems on the sound portion of your board. It could be a bad solder joint causing it to arc to another component or to ground. It could also be just a plain ole bad Amplifier or something. When you mute it you turn all the voltage off to your AF Amps and naurally the noise will stop. Find the sound board and check it for cold solder joints.
Gillight
Dec 03, 2013 | Televison & Video
My Plantronics Voyager Legend has a constant buzzing noise, it does not work at all. When I turn it off or on, it does not matter, just a buzzing noise.
I just had this happen to me. Like yours mine just kept buzzing and the on and off switch had no effect. It just kept buzzing.
The way I was able to fix it was to reset the device by holding both the mute button and the call pick up button until the buzzing stopped. It took only 3 seconds to fix and it immediately began to work. When I switched it on the buzzing was gone and it was working again.
I hope this helps anyone as I didn't see and answer to this issue online anywhere and had to figure it out myself. Take care.
Mar 18, 2013 | Plantronics Voyager Legend
Tv making loud buzzing noise
A common cause are failure of decopling capacitors in the audio section, and or the circuit board power distribution that feeds the audio board. Most of the capacitors are surface mount components. The standard fix is to start by changing the circuit boards that have the defective parts.
If the set is under warranty, call for warranty service. Out of warranty service is expensive for these TV sets.
Jerry G.
Jun 12, 2012 | LG 32LG30 32 in. LCD HDTV
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
Vizio GV42l buzzing
Vizio makes an ok LCD, but if you notice they no longer make plasma. they stopped last year. Anyways. the buzzing sound is semi serious, it sounds as though you have a capacitor leaking. It is best to get it fixed before it goes out all the way, with it buzzing it will be easier to identify. Best of luck
Sep 12, 2009 | Vizio GV42L 42 in. LCD Television
Need code for Audiovox LCD TV (Model LCD1900W) for COMCAST DTA
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off
Aug 28, 2009 | Televison & Video
32H540S noise problem
contact the NY Service Center for Westinghouse. web is www.asnyonine.com
May 26, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Audiovox fpe 3207 32 in. LCD Television Logo
133 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
