Question about Rolex Explorer II 16570 Wrist Watch
Noisey Explorer 2,
My 4 year old Explorer 2 which has been worn daily since purchased has developed a vibration and buzzing noise when moved quickly or shaken,,,Can you explain what this is and the likely remidy or cost to rectify...
  • 2,334 Answers
The noise and the vibration is coming from the winding rotor loose axle. There can be two causes for it:
1) the rotor axle, bridge and setting (fixing) spring is getting loose. This will be quite easy repair as all it takes is to tighten all screws and replace or tighten setting spring.
2) rotor axle is worn, so, consequently the bridge and the setting spring as well. In this case the rotor axle must be replaced by the new one and re-bushed into the bridge and the new setting spring must be fitted. This takes quite a lot of work and new parts as well.
Can not tell you about the costs, but Rolex repairs has never been cheap. In the U.K.about a year ago I did the repairs as described in chapter 2 and customer was charged £195.00, parts inclusive, and it was cheap by the Rolex standards.
Do not forget to rate, please.
Posted on Mar 07, 2009
I just had the same problem with my Submariner (6 years old) and took my watch to a dealer to have it assessed. While there, the dealer asked if the watch had gone through a period of non-use. It had (just recently around the time the buzzing and vibrations started), so he suggested first winding it to ensure that the spring was fully coiled. After doing so, the buzzing and vibration stopped.
Posted on Aug 29, 2012
The buttons on my chronograph (snd 255) are depressed and wont come out. None of the chrono functions work. The watch is about 7 years old and has been worn daily.
What has happened is the oil and grease from the hand/arm has gotten into the sides of the buttons and have caused them to become wedged depressed. You can try using a little WD-40 on the buttons and see if they will become unwedged. You may have to take the back off and clean around the buttons. If reluctant to do so, take it to a jeweler and have them do it for about 15 bucks.
Apr 10, 2011 | Seiko SND255 Wrist Watch
Tip
Watch glossary: U, V, W, Z.
UNIDIRECTIONAL ROTATING BEZEL
An elapsed time rotating bezel, often found on divers' watches, that moves only in a counterclockwise direction. It is designed to prevent a diver who has unwittingly knocked the bezel off its original position from overestimating his remaining air supply. Because the bezel moves in only one direction, the diver can err only on the side of safety when timing his dive. Many divers' watches are ratcheted, so that they lock into place for greater safety.
UNIVERSAL TIME
The mean solar time of the Greenwich meridian, counted from noon to noon, Often confused with the mean time notion.
VARIATION
In horology the term is usually referred to the variation of the daily rate, i.e. the difference between two daily rates specified by a time interval.
VIBRATION
Movement of a pendulum or other oscillating bodies, limited by two consecutive extreme positions. In an alternate (pendulum or balance) movement, a vibration is a half of an oscillation. The number of hourly vibrations corresponds to the frequency of a watch movement, determined by the mass and diameter of a balance and the elastic force of the balance spring. The number of vibrations per hour (vph) determines the breaking up of time (the "steps of a second hand). For instance, 18,000 vph equals a vibration duration of 1/5 second; in the same way 21,600 vph = 1/6 second; 28,800 vph = 1/8 second; 36,000 vph = 1/10 second. Until the 1950s, wristwatches worked mostly at a frequency of 18,000 vph; later, higher frequencies were adopted to produce a lower percentage of irregularities to the rate. Today, the most common frequency adopted is 28,800 vph, which assures a good precision standard and less lubrication problems than extremely high frequencies, such as 36,000 vph.
WATER RESISTANT or WATERPROOF
A watch whose case is designed in such a way as to resist infiltration by water (3 ATM, or atmospheres, corresponding to a conventional depth of 30 meters; 5 atmospheres, corresponding to a conventional depth of 50 meters.)
WHEEL
Circular element, mostly toothed, combines with an arbor and a pinion to make up a gear. Wheels are normally made of brass, while arbors and pinions are made of steel. The wheels between barrel and escapement make up the so-called train.
WINDING STEM
Element transmitting motion from the crown to the gears governing manual winding and setting.
WINDOW
Aperture in the dial, that allows reading the underlying indication, mainly the date, but also indications concerning a second zone's time or jumping hour.
WORLD TIME
Additional feature of watches provided with a GMT function, displaying the 24 time zones on the dial or bezel, each zone referenced by a city name, providing instantaneous reading of the time of any country.
ZONE
Small additional dial or indicator that may be positioned, or placed off-center on the main dial, used for the display of various functions (e.g. second counters).
ZODIAC
Circular belt with the ecliptic in the middle containing the twelve constellations through which the sun seems to pass in the course of a year.
on Jan 11, 2010 | Watches
This watch will not keep working. I spin it around and it works for a min. or two.... is there a way to manually wind this watch?
An automatic watch can be wound up by holding them level and swinging it from side to side and several minutes (one maker said swing it 200-300 times).
Once fully wound, the watch should keep working if it is worn daily. Most automatic watches will run for 2-3 days if not worn.
Dec 20, 2010 | Lucien Piccard Automatic Diamond New...
I have a new, purchased ar an auction so no paperwork a Cartier pasha woman's wristwatch. I don't know how to wind it. Please tell me
There are several models of this watch and you don't say which one you have but thi range are either automatic (which means that it is self winding) or quartz (battery driven).
If it is not going it could be
(1) (for a quartz watch) the winder has been pulled out (push it back in) or the battery has expired. (Do you know how old the watch is?).
(2) If the watch says "automatic" on the face, then it haas probably just run down (they run for 2-3 days if they are not used). If this is the case, holding the watch horizontally, swing it gently from side it side for a few minutes (this will operate the self winding mechanism) and the watch should then start. To keep an autimatic watch operating it needs to be worn daily or placed on a winder when not in use.
Aug 23, 2010 | Watches
Second hand stops for a few seconds and then starts again over and over again
Try manually winding it (assuming it's not a quartz watch). If a mechanical watch is not worn daily it will run down and need to be manually wound to get going. Turn the crown clockwise about 40 turns.
Apr 25, 2010 | Tag Heuer WK1120.BB0314 Wristwatch
Wenger field chronograph only works when not in use
Take or send it back to your supplier, with an explanation of the problem.
Feb 06, 2010 | Swiss Army Wenger Sportedge Bracelet Watch
Carrera automatic. stops with 8 hours of non wearing
Hi
I hate to be blunt be if it stops after 8 hours of wear, it may need a service! Most watches (particularly automatics which winds constitantly, when being worn).
Take it to your local watchmaker for a assessment? If it's less then 2 years old take it back to your place of purchase with reciepts as most swatch group (rado, longines, and tag etc) have a 2 year international g/t (that what we have here in australia and way, please consult your warranty card for verification!)
Jul 13, 2009 | Tag Heuer Watches
Casio G-Shock GW-300 replacement bands
I have a Casio g-shock gw-330a and now find myself again replacing the band. So far, $60 on bands. They last me two or three years. To install the band, take the band and watch to a Jeweler. My local Sears does it for me. $5 for installation; $5 for purchase shipping; $20 for band. $30 every couple of years.
This cost disturbs me.
Jun 09, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Seiko Kinetic Watch model 8D0557
For sure it is time to replace that old capacitor and replace it with the latest solution that uses a Lithium Ion battery. Find a good experienced repair person to do this for you. I do this daily and I am a Certified Master Horologist/watch repairman.. Ron at TimelyWatchRepair.com
Oct 20, 2008 | Seiko Kinetic watch
ROLEX QUICK-SET FEATURE
1) un-screw the pin by turning it towards you, until the spring pops it out. 2) pull the pin out to the next notch 3) turn the pin towards you and watch the date change (if the minute hand is moving when you turn the pin, you pulled out too far).
-Mike
www.perfect-timing.biz
Apr 15, 2008 | Rolex Explorer II 16570 Wrist Watch
Rolex Explorer II 16570 Wrist Watch Logo
645 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
