Question about Whirlpool Washing Machines
When we use our duet whirlpool front load washing machine,we get up the next day there water in the machine.
  • 320 Answers
Q - My washer seems to keep filling with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Mar 07, 2009
  • Whirlpool Master
  • 19,396 Answers
That means that the drain system is not working fine or that you have reflux from drain lines.
  • Ginko
    Ginko Mar 07, 2009
    Try first closing the water faucets at the back, if you get no water, then the problem was a faulty inlet valve, slowly letting water in overnight.
    If the problem is that machine does not drain completely, then you have a defective drain pump, a faulty water level switch, or a problem with drain lines.
    Reflux from drain line is also possible, with water getting back on the machine overnight from drain.
    You find out by ensuring that there is no water after cycle and leaving water supply to machine closed overnight.
  • 5911 Answers
SOURCE: Whirlpool Duet front load washing machine
The following link explains the "FH" error code:
This is one of the more "involved" error codes that has many possibilities for the cause. I would start with the simple things, first, in an attempt to rule out easy the possibilities. Check your fill hoses to ensure they are not kinked or clogged, followed by verifying your installation to ensure you don't have a siphoning problem, Then, check the drain pump for operation. Read through the link thoroughly andlet me know if you have questions. I hope this helps you.
Posted on Jan 17, 2009
  • 415 Answers
SOURCE: canyou adjust the water level on a whirlpool duet
no and if you fill by hand and attempt to start an wash cyc it should pump out the water first
Posted on Aug 24, 2009
57 varieties
  • 1653 Answers
SOURCE: My whirlpool duet front load washing machine stops in mid cycle
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Posted on Oct 02, 2009
  • 15935 Answers
SOURCE: I have a Whirlpool Duet front-loading washing
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
  • 13 Answers
SOURCE: How to add powdered Calgon water softener to
try to put it in where the fabric softener goes, just curious why would you put water softener in your machine?
Posted on Nov 08, 2010
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ... > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
Aug 22, 2013 - Uploaded by
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
How to add powdered Calgon water softener to Whirlpool Duet front-loading washing machine.
Nov 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: front load whirlpool washing machine runs fine unt...
You can try this:
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I just came back after a 5 day trip and found water in my whirlpool duet front load washing machine. How did it get there?
This is usually the result of an impurity in the water supply which has made it past the inlet screen and gotten to the diaphram in the water valve, allowing a bit of water to slowly seep into the machine. Sometimes, just running the next cycle will flush it out, and fix the problem for you. If not, you will have to replace the water inlet valve. (the part the fill hoses screw onto on back of the machine)
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our front load whirlpool washer gradually fills over the course of the day it is like there is a slow leak into the washer
water inlet valve in the machine is either sticky or faulty. get it replaced. till the time, after wash, keep your water valve (which supplies water to the machine) closed
Mar 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sometimes the next morning after I have washed a load of clothes that evening, even though at night there is no water in the bottom of the machine, the next morning there is a small puddle in the bottom. ...
i think the drainage of your washing machine, is not functioning well,or it has a leak, that's why some water remain in the bottom of your machine..
check this one..
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water filling up in Front loading Whirlpool washer
sounds like you have a faulty water valve that does not close when the power is not supplied to the machine.or a problem with the cotrol board supplying power to the valve when the unit is not in use
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Canyou adjust the water level on a whirlpool duet front loading washing machine model ghw9150pw3?
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water is pooling in the wash tub even after the cycle has completed. the next day, the tub is full of water and leaking out the front
Your Mixing Valve (water valve) is not shutting properly.
Replace it to solve your problem.
Thanks for using FixYa!!
Jul 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
