Question about Kenmore Washing Machines
Machine does not spin...makes a noise
Machine does not spin...makes a whining noise.
  • 163 Answers
Your drive coupler is most likely broken.It is located between the motor and transmission.very easy fix.you will need to take the screws from the face of the machine out and lift the face .make sure to unplug.their are 2 gold clamps that hold your cabinet in place.take screw driver and pop clips out.pull your lid switch connection loose and pull cabinet off.you will see your pump in front bottom of machine.remove clamps that hold pump in place then remove the power clip from your motor.remove 2 clamps that hold motor in place and your drive coupler is their.it will be 2 white plastic pieces and a black rubber piece in center of 2.check if teeth are broke or if craked.
Posted on Mar 07, 2009
Whining noise from kenmore elite washing machine during spin cycle
it is poss. the bearings are going. if you can spin the drum by hand and it makes the noise it is the rear bearing...
May 06, 2014 | Kenmore Washing Machines
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
When in spin cycle machine makes a very loud whining noise
Most common cause for your whining noise is because the seals have failed/worn and allowed water into the bearings..Rusty ball bearings are not smooth...Hence the noise.....Probably needs bearing/seal and probably shaft replacement....Big job..Get quotes....Good luck...Nomess
May 20, 2010 | Washing Machines
Spin Cycle "Whines" and keeps spinning after cycle is complete
need make & model # to correctly solve problem, it could be timer shorted or the drive motor has gone bad.
Oct 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
May 06, 2009 | Amana Washing Machines
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Front load washer makes whining noise on spin cycle
Check to make sure that your machine is still level using a regular carpenters level. If it is not, You may be able to level it by screwing on the legs until it is level. But carefully and not too much at once.
Aug 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Washing Machines Logo
26 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
