Question about Whirlpool Duet GHW9150P Front Load Washer
Control panel light is on
The light is on orange and it says control panel is locked, how do I unlock the control panel
    President:
  • 1,294 Answers
Press 'end of cycle' button for 3 seconds.
Rate please?
Posted on Mar 08, 2009
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
It says CONTROL LOCKED.... how do I get it unlocked??
  • Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
  • Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
  • Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
  • They designed that mostly for kids sorry pain I know just be calm feel saving some ones child thanx
    Dec 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet dryer
    Oct 22, 2013 | Dryers
    Control lock lit, no other buttons work
    Instructions
      • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
      • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
      • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
    Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
    Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
    Looking for the speaker colors for a 2001 Jeep Grand Cherokee
    Item Wire Color Polarity Wire Location
    12V red & pink/black + ignition harness
    STARTER yellow + ignition harness
    IGNITION dk. blue + ignition harness
    ACCESSORY red/black + ignition harness
    SECOND ACCESSORY none
    TACHOMETER *6 *6
    POWER LOCK orn/blk - orn/pur *7 5wi door lock switches *1
    POWER UNLOCK pnk/blk - pnk/pur *7 5wi door lock switches *1
    PARKING LIGHTS + use (-) lights
    PARKING LIGHTS - dk. blue/pink *2 steering column
    DOOR TRIGGER *4 - *4
    HEADLIGHTS yellow *3 at the headlight switch
    WIPERS dk. green/red - steering column
    LF WINDOW UP/DN lt. blue - white A drivers door lock switch
    RF WINDOW UP/DN brown - purple A passengers door lock switch
    LR WINDOW UP/DN dk. blue - red/wht B drivers kick panel
    RR WINDOW UP/DN gray - dk. green B passengers kick panel
    TRUNK/HATCH PIN tan/black - BCM, above diagnostic plug
    HOOD PIN none
    TRUNK/HATCH RELEASE none
    FACTORY ALARM ARM arms with lock *7
    FACTORY ALARM DISARM lt. green/orange *7 - *5
    HORN TRIGGER gray/orange - steering column
    BRAKE WIRE white/tan + drivers kick panel
    LOCK MOTOR orange/black drivers door lock switch
    UNLOCK MOTOR pink/black drivers door lock switch
    DISARM DEFEAT pink/purple passenger kick panel
    DISARM NO UNLOCK none
    DOME SUPERVISION yellow/dk. green *7 - BCM, above diagnostic plug
    SPEED SENSE white/orange PCM, passenger side firewall
    SUN ROOF OPEN/CLOSE none
    SUN ROOF LIMIT none
    LF SPEAKER grn/orn - brn/red at the radio
    RF SPEAKER purple - blu/pnk at the radio
    LR SPEAKER wht/grn - grn/wht at the radio
    RR SPEAKER grn/wht - blu/orn at the radio
    RADIO 12V red/white at the radio
    RADIO GROUND black at the radio
    RADIO SWITCH white/red at the radio
    RADIO ILLUMINATE none
    POWER ANTENNA none
    Notes: NOTE: Jeep vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 Use orange/black and pink/black at the drivers door lock switch to lock and unlock the drivers door. Use orange/purple and pink/purple at the passengers door lock switch to lock and unlock all of the other doors. *2 The dk. blue/pink will flash the hazard lights. They will flash even with a latch input to the wire. The parking lights can be activated by using a 1300 ohm resistor to ground on the yellow headlight wire. *3 Use a 330 ohm resistor to ground for headlight activation. Use 80 ohms to ground on the same wire to operate both the headlights and parking lights. *4 There are 4 separate door triggers wire, one for each door. Use all 4 wires and diode isolate each together. The drivers door is tan/red at the drivers door lock switch. The passenger door is tan/red at the passengers door lock switch. The drivers rear door is tan/orange and the passengers rear door is tan/yellow at the BCM. WHEN USING A 455J INTERFACE MODULE, IT IS NOT NECESSARY TO USE THE SEPARATE TRIGGER WIRES. USE THE YELLOW WIRE AT THE UNDERDASH LIGHT FOR DOOR TRIGGER. *5 Factory alarm disarm requires a 463 ohm resistor to ground on the lt.green/orange wire at the drivers door lock switch, you MUST use a relay. *6 The 4.7L motor has a separate coil for each cylinder. Go to any coil and use any wire that is NOT dk. green/orange. On the 4.0L motor use any of the tan/stripe wires at the coil pack, or go to one of the fuel injector and use the wire that is NOT dk. green/orange. *7 Can also use DEI part number 455J door lock interface control module. This will control door lock, unlock, arm, disarm, dome light supervision and more.
    Sep 26, 2011 | Car Audio & Video
    The controls locked is displayed. what causes this and how do i get the controls unlocked.
    Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
    Control locked will not unlock
    It might be a child lock. You have to press and hold the a button for 5 seconds. You have to find which button yourself by looking at the panel (it usually says which one is child lock on it). Could "end of cycle" or "load signal" button.
    kenmore stove repair in orange county, ca
    appliance repair orange county, ca
    Feb 08, 2010 | Washing Machines
    Maytag washer panel show a red light that say control lock what if anything i can do to releaseit
    Try the "End of Cycle" button to the right of panel front, next to Start button. Mine says hold for three seconds to lock/ unlock control.
    Mar 10, 2008 | Washing Machines
    Whirlpool Duet GHW9150P Front Load Washer Logo
    46 people viewed this question
    Dan Webster
    Dan Webster
    Sal De GO PATS
