Question about Acer Aspire 3680 Laptop
When i boot up i get a message that my hard disk failure is immenent is there anyway to repair this problem
  • 1,031 Answers
If you get a "Disk Controller Error" error messages that may occur before Windows XP or Windows 2000 is started. Imminent Hard Disk Failure This error may appear when the hard drive detects that it will fail or stop working sometime soon.
Backup Data Before Proceeding Although the notebook may continue to start Windows after displaying the message, it is advisable that you immediately backup your personal data from the PC by copying it to a Network Drive, CD, DVD or USB storage device. After completing the backup, use one of the following methods to resolve the error. Step 1: Test the Hard Drive Use the steps below to test the hard drive in a Notebook PC using the HP Hard Drive Self Test.
  1. Plug the AC Adapter into the Notebook PC.
  2. Press and hold the Power button for 5 Seconds to turn off the PC.
  3. Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
  4. After the BIOS Setup Utility is displayed, use the Right Arrow key to select the Tools menu.
  5. Select Hard Drive Self Test
  6. Press the Enter key to start the test.
The Hard Drive Self Test will provide an Estimated test time . A Quick test, a Comprehensive test, and a SMART test will execute when the Enter key is pressed. If any test fails , order a replacement hard drive. If all of the tests pass, the hard drive is not damaged.
If all tests pass , press the power button to restart the PC. The error was most likely a result of a shock to the PC triggering a SMART error from the Hard Drive. Since the Notebook PC passed the Hard Drive Test, it is safe to use.
Posted on Mar 07, 2009
  • Starnley Johnwells
    Starnley Johnwells Mar 08, 2009
    hope this this helps pls appreciate by rating as fixya
    Brigadier General:
  • 5,158 Answers
No.... back up all the data on the hard drive that you want to keep and replace the hard drive. if you continue to ignore it .... it will not boot suddenly and you will have lost all your data.
Media test failure message. Reboot and Select proper boot device
A hard disk failure can be catastrophic if it jeopardizes the data stored on your computer.
In addition to rendering a laptop inoperable, a failed hard disk can damage other files stored on the drive as well.
It is critical to determine whether an actual drive failure has taken place, and there are several steps to troubleshoot a drive before hard disk failure can be declared.
Unplug any devices such as printers, speakers, cameras and other external peripherals. Boot the laptop by pressing the power key.
If this does not result in a successful boot, try booting Windows in "Safe Mode."
Reboot the computer, and hold down the F8 key this will vary depending on your computer and operating system
From the menu choices, choose "Boot Windows in Safe Mode".
If the boot up progresses, then the computer is likely experiencing a software issue, not a hard drive failure.
Reset the hard drive.
This will involve turning off laptop (removing the battery is a good move, too) opening the laptop unit, and unplugging all connections and cables from the hard drive.
If possible, replace the hard drive with another drive.
This will help determine if the hard drive is causing the problem.
Plug all connections back in to the hard drive, and reboot the computer.
Repeat Step 2 if necessary.
If the computer does not reboot, the laptop is more than likely experiencing a hard drive failure and will probably have to be repaired by vendor.
hope this helps
Oct 09, 2012 | mpc X3000 Laptop Transport 14.1" Barebone
I have an Optiplex GX 620 Mini Tower that displays a NIC failure error at boot. The error message reads "NIC failure. Press F1 to reboot or F2 to go in to setup." The PC did not boots
it means your hard disk is not detected by system, check all connections of hard disk, if problem remains check with another working hard disk
Jul 29, 2012 | Dell OptiPlex GX260 PC Desktop
When I restart computer, I get a message saying immenent failure, Hitachi Drive O, Smart??
well, error like that appears when you usually transfer files from one driver to another driver.the message appears before the start up window..but though error appears hard disk will still function..anyway, just to make sure have a back up copy of all your files..
Feb 22, 2011 | Computers & Internet
On the Boot-up screen I get the message: "Diskette
I think you should press F2 to go to the setup page.
There, you should change the order of your boot device.
set the first boot device to hard disk
set the second boot device to cd rom
and the third to floppy.
follow the instructions and click save and continue
Dec 22, 2010 | Dell Inspiron 530 Desktop Computer
1720-SMART HARD Drive detects immenent failure. What shall I Do?
Sounds like your hard drive is about to pack up. You can disable SMART for your hard drive in your CMOS setup. which will allow you to boot up your pc. I suggest you back-up all your data as soon as possible before the hard drive fails completely.
Nov 29, 2008 | HP xw6600 Workstation with 650W 80 PLUS...
ACER SMART failure
SMART means self monitoring and reporting tool, this is the option which performs certain test for the status of hard disk health, if its coming it means condition of your hard disk is not good, its better if you immediately back up your data and replace it, by the way you can also disable this warning through the bios, just disable the smart feature in hard disk
Nov 10, 2008 | Acer Aspire 3680 Laptop
When booting my laptop I get the following message: SMART Failure Predicted on Hard Disk 2:WDC WD1600BEUS-22RSTO-(S1) and a WARNING: Immediately backup your data and replace your hard disk drive. A failure...
welcome to fixya
you will need to contact the maker of the computer unless they tell you to take back to best buy ...
i hope this helps you out have a good day
Aug 04, 2008 | Gateway Computers & Internet
Disk boot failure, insert system disk and press enter
The drive should be set with jumpers or cable select to be primary master. Some pc & drive combinations don't like cable select, others insist on it. Try both, one at a time.
Jul 15, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
When starting up the laptop I get a message saying hard drive failure is immenent. To please back up hard drive then remove. But as I try to boot it up to back up hard drive it just restarts.
Sounds like the drive has already failed
Try logging into safe mode
at start up start tapping the f8 key
select safe mode from the options
let me know if you can get in like that
Jul 15, 2008 | Toshiba Computers & Internet
Acer Aspire 3680 Laptop Logo
263 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
