Question about Compaq (12XL310) PC Notebook
Automatically ctrl key is pressed
I am having Compaq presario 12xl222 notebook. While booting the ctrl key is automatically pressed and the shortcut is activated while working with ms-office. Sometimes it is working properly and sometimes it showing this type of problem. While opening ms-word a messege box displaying the messege that " word has detected that ctrl key is pressed. Are you want to open in safe mode?". The is is responding properly when it is not automatically activated. Please solve my problem at your earliest.
I had the same problem and now it is solved... just download KEYTWEAK software and disable ur ctrl keys...
it worked...
Posted on May 02, 2012
First make sure that the keyboard is ok, you can press the ctrl key and compare with the feeling when press other keys, to see if there is different, may be some thing stuck there, if there is no problem, check the driver is installed correct, you can get the keyboard type from the check list of the computer or contact with the supplyer, and install a correct driver
Posted on Aug 02, 2007
Compaq stuck in utility mode
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
If this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Feb 14, 2013 | Compaq Armada 1750 Notebook
Fn key + print screen dont work at compaq presaqrio cq40
Have you tried pressing Alt+Print Screen.
Or just pressing Print screen
Jan 25, 2013 | Compaq Presario Notebook
Keyboard problem
Try pressing both the left and right CTRL keys at the same time and
see if that releases CTRL.
Go to Start / Settings / Control Panel / Accessibility Options /
Keyboard Options.
Turn off CTRL lock if it's on.
If that solves it and to avoid future problems, press "Settings"
Turn off "Press modifier key twice to lock".
Turn on "Turn sticky keys off if 2 keys are pressed at once".
Or turn off "Use shortcut"
Clean your keyboard.
Cleaning Laptop Keyboard
http://www.computing.net/howto/simple/keyboard/
hope this helps
Sep 04, 2012 | Compaq Presario C716TU Laptop Charger...
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
My screen turns sideways and when i download a game it turns sideways automatically
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key. Restore by pressing Ctrl-Alt plus the up arrow key. ALSO To change the display from portrait to landscape Press Ctrl-Alt plus a left or right arrow key. Some computers do not have this function.
Aug 22, 2011 | Compaq Presario CQ56-115DX Laptop
The shift keys and ctrl keys on my nc6230 laptop have stopped working. Any solutions?
Clear temp files and reboot
If you're using Skype turn off keyboard shortcuts
Make sure sticky keys are turned off
Keyboard cable/keyboard may need to be replaced
Nov 23, 2010 | HP Compaq nc6230 Notebook
Ctrl+Alt+Del to restart error
Is it a black screen right when you boot your computer? If so this could be a fatal disk error and the harddrive has crashed.
There is no easy fix other than to replace the harddrive.
Oct 05, 2009 | Compaq Presario 700 470024-192 Notebook
Regarding driver of shortcut keys of compaq presario c773 notebook
audio driver of my compaq c773 notbook is not installing..... what should I do.?
May 17, 2008 | Compaq Presario 700 470024-192 Notebook
My presario v3000 laptop - my name is bec
Dear,
its mean the Boot Manager is damaged of this laptop, you have to re-install Operating system.
Takecare
Mar 27, 2008 | HP Compaq Presario v3000z Notebook
Outlook Express
ther is a shortcut key u can use if u click any e-mail then hold ctrl and press A this will highlight all e-mails then hit the del key to clear them out. this shortcut works in any folder it not only for outlook
Nov 18, 2007 | Compaq Presario 5000 PC Desktop
Compaq (12XL310) PC Notebook Logo
829 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
