Question about Kenmore 84052 Dryer
My Kenmore 90 series dryer's pilot light is out. What can I do? I have a Kenmore 90 Series Model 76912692, Stock 76912, Serial No. MG2701491. Is it straight forward to change the igniter? How much does it cost, approximately?
  • Kenmore Master
  • 8,220 Answers
If your flame sensor is open then the ignitor will not fire up. Read more
Post your model number to any of these fine forums for
a simple answer that will save you lots of money:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
Posted on Mar 07, 2009
How to light pilot for Kenmore 70 series Gas dryer
In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate. If you are having difficulty locating this identification label, follow this link which will take you to our Website where we have pictures of common locations where your model number ID label can be found. Here is the link: http://www.affordableappliance.com/Tips/modelnumbers.htm Once you have the updated information, please reply to this email. Eric Campion
May 21, 2014 | Kenmore 73952 Gas Dryer
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
I have a Kenmore 90 series dryer.The only number
the door should have a sticker where it closes against with model and serial numbers as for the second part ck terminal connection to elements to make sure they are tight next shoot continuity of the elements limit switches thermal fuse elements will be between 9 and 13 ohms others should read 0
Jan 28, 2010 | Kenmore Dryers
Kenmore 90 series propane gas dryer
Hi, You should not have a pilot light, There are electronic ignitors on the dryers. Unless this dryer is 40 years old, just start the dryer and the heat should come on.
If the heat does not work, there must be another issue.
Please let me know if I can help you further.
Thanks
Vic
Jul 21, 2009 | Kenmore 63942 Dryer
My Kenmore 90 series dryer's pilot light is out. What can I do? I have a Kenmore 90 series gas dryer and its not getting heat.  If I look at the igniter which is a carborundum igniter and I don't see...
Hi, You should first check the fuse. If the back comes off try this:
UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If the rear panel does not come off, please get me model # and I can assist you further.
Please let me know if this helps you.
Thanks
Vic
May 28, 2009 | Dryers
What is the drum capacity of my kenmore series 90 model 76912692 dryer
most are between 9-12 pounds,washer are the seem-mike
Apr 22, 2009 | Dryers
Th pilot won't start ,motor start but won't light the pilot
I have a Kenmore Series 80 (Model # 66812694, Stock # 66812) that will not start. The light comes on, but no power when you push the start button. I have checked the fuse box and everything is fine. I've also tried unplugging for 10-15 minutes and replugging it in, but no success. Any suggestions?
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
How to light the pilot for gas dryer, 90 plus series
Dryers haven't used pilot lights in over 30 years. You have an electronic igniter
Jan 16, 2018 | Kenmore 74602 Gas Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Kenmore 84052 Dryer Logo
974 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
